- Joined
- Oct 25, 2020
- Threads
- 25
- Messages
- 299
- Reaction score
- 603
- Location
- Atlanta, Georgia
- Vehicle(s)
- Porsche 911
- Your Bronco Model
- Outer Banks
It's a pretty simple formula, the tune essentially cranks up the boost on the turbo and modifies standard air fuel ratios. Burger or Cobb will say it's more complicated then that (and I'm sure it is), but cranking the boost up is necessary to see these types of gains. I haven't looked into the Bronco specifically, but my guess would be that they have doubled maximum boost pressure and modified the throttle to achieve the numbers they are posting. That's double the stress on the turbo. Average turbos last about ~100k in stock form. It's essentially a very expensive wearable item.I mean, listen I’m not mechanic and have zero experience with tunes but… I have a hard time believing my wife’s grocery trips in the Bronco is going cause hectic problems. But what do I know. We are not rallying this thing. Hell, it won’t ever even see a normal car wash. Babies you might say.
By cranking the boost, you stress your engine's internals beyond what they were "designed" for, and you stress the factory air/fuel management system. Can the stock system handle it? For now yes, but for how long. Even at half throttle, the boost is cranking beyond the turbo's factory limits. I'm not positive, but was told that some of the internals on the Bronco are forged, which will def help handle some additional power. With that said, most likely it is the support items and the turbo itself that will start to go prematurely. Not the engine.
Just look at the all of the tuned turbo 4 cylinder VW's out there and the tuned BMW's. Probably the two most popular manufacturers in the tuning world. They are a nightmare to deal with when you start cranking up the boost and pumping out miles. I had a JB4 and then a Cobb tuned 335i. It was an absolute monster and a blast to drive with the tune, but as soon as you start pushing beyond the factory, here comes the misfires and shadow codes, wastegate rattles, blown turbos, oil making it's way through the charge system, blown charge pipes, carbon build up. It's a slippery slope. I see no reason why the Bronco or any other factory engine would be immune to these issues when tuning.
I am so tempted to run a tune on this Bronco. If eventually I give in, it will be the Ford factory tune. Not because I think they will do anything drastically different than Cobb or Burger, but at least the manufacturer will be responsible when issues start happening as a result. Out of warranty will just be SOL.
