JKS Manufacturing Max Tire Clearance & Steering Sleeve
Broncoman7072
Pell City, Alabama
72 Bronco, 70 Bronco
Sasquatch with 3 inch lift 37 STT PROs on 17x8.5 0mm offset rubs these areas with sway bars connected. I have a need for this.
My kit is scheduled to be delivered Monday.
These people that say 37s fit with a 1" level are on road only or using small 37s.
Rockdawg84
Sam
Tucson, AZ
98 4RUNNER, 96 F350 CC 4x4
I was about to cut into those mounts and build my own body mount but this will be much easier. Ordered. BTW Im running 37x12.5r17 Micky Thompson Baja Boss MT's on Sasquatch suspension and barely rub on the front crash bar brace. This will be sweet?
Ford Bronco JKS Manufacturing Max Tire Clearance & Steering Sleeve 399F3D30-6EB6-4259-8F08-BD45D1C11410
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
Just ordered the steering sleeve
Frankie945
Frank
Louisville KY
Q50
I assume new alignment after adding the steering link fix?
As long as you mark where the jam nut was before taking it off you shouldn’t need a alignment. I plan to do that along with measuring the tie rod length to be double sure, it should go back at the exact length it was.
Draughon
Daylon
Dallas
BMW 4-Series
Steering sleeve looks like a dead-simple upgrade. Nice work!
Jgtln
Jason
Festus
Gmc
Had anyone installed the sleeves yet and tested them out?
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I installed the sleeves, not a bad product just kind of hard to adjust alignment. I can see an alignment shop giving you a bad time. I used a pair of knipex on the small portion of exposed tie rod to adjust everything. Got an alignment set up for Monday due to lift so I will see if they want more labor.
I doubt I am going to be the one giving the product a workout. I might go play off-road, but nothing that should stress since I have no lockers or skid plates.
Rockdawg84
Sam
Tucson, AZ
I installed the Body mount chop today. And I will say that it was not very hard. and the Results are great and very clean and looks totally OEM. I did not remove the front bumper as I had the fenders off (adding Advanced Fiberglass Fenders). I'm running stock Sasquatch suspension and Sasquatch wheels.
Ford Bronco JKS Manufacturing Max Tire Clearance & Steering Sleeve 712616AB-099F-45AE-B769-483F52F7CAB3
Ford Bronco JKS Manufacturing Max Tire Clearance & Steering Sleeve 4EAA564C-8F68-4A38-9413-AC4BE0303061
Ford Bronco JKS Manufacturing Max Tire Clearance & Steering Sleeve C4BD2199-08C2-41AE-B96A-D70685FC003A
Ford Bronco JKS Manufacturing Max Tire Clearance & Steering Sleeve 23242EC3-5F25-4E05-8DE2-102356FC866D
Ford Bronco JKS Manufacturing Max Tire Clearance & Steering Sleeve 4C87CF00-D84B-47A7-817D-310E3C5E4393
Ford Bronco JKS Manufacturing Max Tire Clearance & Steering Sleeve A975BAA4-29E9-405C-A6AC-5DA10AEC604D
Ford Bronco JKS Manufacturing Max Tire Clearance & Steering Sleeve 3B775E92-0EA7-4CE9-BA27-B1202E00A5BE
Ford Bronco JKS Manufacturing Max Tire Clearance & Steering Sleeve 2FC46375-0819-41BA-8855-4BBF2AFFB495
Ford Bronco JKS Manufacturing Max Tire Clearance & Steering Sleeve D8EDFA9D-1AE4-4E3A-8009-CB5A3B8D4B60
IwannaGOfast
Jon
Brea, CA
1991 Ranger Long Travel, 2014 Cruze Commuter
Looks good. I was hoping to install mine on Sunday, but it is going to have to wait until next weekend.
Rockdawg84
Sam
Tucson, AZ
you're going to love them. One suggestion on the front mount is to cut back to front and you will not have anything to grind, just clean up. I have a Badlands Sasquatch with the 2.7 and couldn't put a jack on the body cross member so I waited till I went to reassemble and then lifted the body from the outer part of the front crossmember. You must lift the body or you won't get the top bolt back in. Have fun and post up your results
RainbowStix
A Big Island
Toyota Tacoma
LOL!!! Thanks, my high package worked great with the 37" KO2s. No lift needed and no rub and I have about an inch of clearance pulling into the garage. Any more lift I'd be screwed...
The only reason i mentioned about the crash bars is my buddy is still doing therapy bcuz he was hit that was and crushed his legs.
If you’re concerned about safety, keep the crash bars and definitely don’t run 37s. A bigger, heavier tire has more of a chance to go into the cab, especially without crash bars. Don’t try to outsmart safety engineers.
ZipZit
Zip
Las Vegas NV
2020 Escape, 2008 Mazda3
It looks like a Mickey Thompson 37x12.50r17 tire ends up with a diameter of 36.38" (depending on which model) Are you saying with a Badlands Sasquatch package, using the 17x8.5" Sasquatch wheels, this JKS clearance kit is all that is required? (i.e. no additional lift kits beyond factory Sasquatch) ?
I'm curious.. what did you do with the original Sasquatch Goodyear Territory 315/70R17 Mud-Terrain (M/T) tires? Were you able to sell those somewhere for a reasonable price?
Edit: I do see a lot of these tires on Ebay, including free shipping... Perhaps your old tires went in that direction?
Many thanks for sharing your info here...
Rockdawg84
Sam
Tucson, AZ
That is exactly what I am saying. bone stock except for the JKS clearance kit with Mickey Thompson 37x12.50r17 which are 36.8" clear great. The only slightly rubbed before the clearance kit.
As far as the stock tires, I sold them to a friend for $1250 for all 5 tires. was a win win as it brought the cost of my 37's down to just over $1000. I had several people lined up for the tires. Ironically I had tried to do a trade in with Discount Tire and they were not interested in them at all. No sweat for me as I went to a local shop and got a great price and helped a local shop. Win Win
ZipZit
Zip
Las Vegas NV
Awesome. You are my hero! And I gotta ask. Did you pick up beadlock rings, and install the tires beadlock method?
