Just test drove a 2 Door WT ... Eh! Some disappointing discoveries.
airishfan
rob
North Las Vegas
jeep cherokee
If you wait a few years to get a Bronco then I am sure Ford well fix and change some of the bad .
Silver-Bolt
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
The engine is detuned for the break in period so that would explain the lack of power. I anticipated the sound being lack luster. No plan to put speakers in the door but I will find a way to upgrade the system once I get it. Small speakers on the dash might go a long way.
The engine is detuned for break in? What is your source for this info? There is no detuning for a break in period. If the dealer put in 87 oct fuel it would be down on peak power. There is no magic in the ECU to turn on additional power at a set mileage.
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
As an owner of multiple Fords, the standard speakers have always sucked. I've upgraded all the speakers in my last 2 trucks and will do so with the Bronco when I eventually get one. I've accepted it as a fact of life. I do like my wifes Alpine system that came in her Jeep, but alas, Ford only allows the 'good speakers' on certain trims.
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
I love reading these because so many people have no idea what a bronco is... EDIT:. We all want the bronco for different reasons. For me, this thing will cover gnarly terrain and get me way back into nature and then do 75 mph on the freeway on the way home. These things just aren't made to be city drivers. Test drives should be held on BLM... Then we can have some real discussions.
You’re right! I’m comparing it to the Bronco it was designed after, the Original 1st Gen 66 to 77!
So this thing is just like a freaking Rocket-Launching-Off-road Cadillac! in my opinion, and it halls ass! More then Anything I have ever had !
I have built Street Drag motor small block V8s that weren’t as quick
Also….the design is so freaking cool when you compare to the original. A lot of the people here only know the Bronco that OJ drove, basically an F150 with a camper shell.
I don’t know, I think some of the people out there think this thing is going to be like a range rover or something? Go spend $100,000!!
SpeedLimit18
Jackson
Braselton, GA/Oxford, MS
Grand Cherokee SRT, Z51 CMG C8
You obviously dont own a C8.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
He's not suggesting that no engines are ever detuned for break-in. (The C8's engine obviously is, and GM clearly states that in the C8 owners manual.) He's just challenging the conventional wisdom that keeps getting repeated on the forum that the Bronco engines are detuned for break-in.
FWIW, I started a new thread yesterday to address this very issue. Here is the link.
AP_2004
AL
E46 M3, IS250
I have read a few complaints about the speakers already. I am assuming you’ve never driven a wrangler then. When you take the front panels or whole top off the speakers are kind of useless anyway. If audio is an important feature to you, I highly recommend test driving a wrangler with panels on and panels off to get a reference.
True but the Bronco I drove was lackluster with all the windows up and a closed soft top. I can only imagine what it’ll sound like with windows down, tops removed. It’s definitely going to be at the top of my upgrade list.
Grey Goose
Kansas City
2018 Audi SQ5, 2018 Volvo XC90
Drove a two door with the 2.7 on Saturday. Very disappointing. Very slow. Likely cancelling my order.
Felt like 200 hp rather than 320+.
wjfawb0 [hacked account]
Tennessee
2015 Jeep Wrangler JKR
Same here. The speaker system in my '10 F150 XLT, wife's '12 Titanium Focus, '13 Explorer Limited, my '15 Mustang GT all are pretty pathetic. The Alpine upgrade in my '15 wrangler rubicon is the best factory system I've ever had. And, at that time, the factory radio is a double din unit that is very easy to swap out for aftermarket without touching the factory amps and speakers. I upgraded speakers and added a custom trunk sub in my '15 Mustang GT, but it still sucked compared to my '15 Wrangler's Alpine system. I considered added door speakers (liek Ford's high end mustang package), but at the end of the day, with Forscan and all the integrated crap in the ford I just sold the car.
BabyDoc1012
New Bern, NC
2020 Sierra, 2019 Ascent
I wasn’t clear in my original post, I meant that the audio is lack luster with doors on, windows up and top on. My wrangler with a hardtop was meh at best and that was the upgraded audio. With the front panels off, I didn’t even bother.
AP_2004
AL
E46 M3, IS250
Can’t speak for the upgraded audio but the main advantage I see is having roll bar speakers in the back seat area instead of in the cargo area. That does give the Jeep a slight edge but both Bronco and Jeep would need an upgrade to give the sound some more punch. But the Bronco having complete open air is worth the sacrifice!!
mpeugeot
Drove a two door with the 2.7 on Saturday. Very disappointing. Very slow. Likely cancelling my order. Felt like 200 hp rather than 320+.
It was that bad?!? Really??? Wow... that sounds like RAV4 power. Although, if you do the math, it really is RAV4 power. The RAV4 has 205 HP and weighs 3370 lbs; a heavy 4 door Bronco weighs 5100 lbs and has 320 HP. (BTW - RAV4 0-60 is probably about 8.7 seconds).
Simple ratio would suggest that the 4 door Bronco is around 51% heavier... and 51% more HP would be 310 HP. So, that's not completely unexpected performance based on the numbers and the weight of a 4 door; but, this is a two door and should be significantly lighter with correspondingly more gallop.
