Kicker 12" CompRT downfire sub w/passive radiator
ejaffe
New Jersey
Audi TT
Wondering if anyone has experience with this sub. What are your thoughts?
Aztec1382
Sam
F350
Works great
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak
Had the 10” version of this in a previous Bronco, it was more than enough and pretty clean bass for the price
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
CUZICAN
Lake Charles, LA
2022 Bronco Wildtrak Sasquatch
I didn't buy their pre-made box because it is only offered in a dual 4ohm woofer and to get full power out of the kicker key 500.1 you need a dual 2 ohm woofer to get to a 1 ohm load. I did use the CompRT and passive radiator in a custom rear facing box. Now depending on your sub amp, the pre-made box may be perfect for you, but the RMS for that sub is 500w and the key 500.1 only puts out 300w at 2ohm. I did build my box to kickers specs on their box, it sounds great and is more than enough to match the kicker 200.4 on my highs and mids.
Slick85
Richard
Austin, TX
Is the passive radiator to act like another subwoofer? I haven't heard of those until recently...
CT203
Connecticut
'13 JK
I had this in my Wildtrack with the Kicker Key 500.1 and will be doing the same with my BRaptor unless a good JL Stealthbox comes out(supposedly Jan). Sounded great but sounded waayyyy better after I installed Dynomat under the floor.
Maxlider Bros has a kit to make this simple - https://shop.maxliderbros.com/colle...cts/dynamat-2021-ford-bronco-4-door-cargo-kit
How long was the Dynamat process. Disassembling a brand new vehicle makes me feel squirly, but this seems like an inexpensive mod that could make a big difference.
mikey_photo
Allentown, PA
2021 2dr Badlands
I’m running this exact setup with the 500.1 and it works really well and sounds great (for what it is) and, I would do the exact setup again.
Ford Bronco Kicker 12" CompRT downfire sub w/passive radiator F188FFF0-FB68-4317-8864-13E0FDFD9A8F
This picture is before hooking up the 500.1 but it basically comes right off the LC2i and im using the plugnplay harness. My mains are running off the 200.4 key (not pictured behind/above the glove box)
Ford Bronco Kicker 12" CompRT downfire sub w/passive radiator 0E6020A2-B2D3-4D44-8346-D07C6F1C5888
i also did a “faux seat delete” platform in my 2dr and this box works great for that purpose.
Ford Bronco Kicker 12" CompRT downfire sub w/passive radiator BCDFCE7E-FAC3-48AF-941B-BDE1DD0DE290
derichio02
Bo
Southern California
it was literally 4 bolts and 1 trim piece to remove and the dynomat is pre-cut and peel and stick. You can do just the floor if you like so you don’t have to remove the side panels
Indica
Alek
Illinois
‘21 Big Bend
I have it. Thing bangs for sure, running it off a kicker 500 amp. Speakers off the 200.4. Might have to do the dynamat soon. I don’t have much rattling going on but interested to see how it can improve.
Ford Bronco Kicker 12" CompRT downfire sub w/passive radiator A4A24EE6-903E-4B26-BF7E-DAE4174DD3A0
ejaffe
ejaffe
New Jersey
Audi TT
Will the Matt only stop potential rattling or does it improve sound?
Umichigan1
2022 2-Door Bronco
Using a passive subwoofer allows you to use air pressure behind the cone to create added reinforcement. It's similar to using a bass port in a subwoofer enclosure but a little bit better. A passive radiator is nearly identical in structure to a standard speaker but without the voice coil structure or wiring. It will provide much more broad and versatile bass compared to using a single speaker enclosure.
Slick85
Richard
Austin, TX
I'm thinking to do that with Audiomobile as they have an enclosure with a normal shallow sub plus passive radiator
KABQ
Aaron
Albuquerque, NM
Do you have a picture with the seats down and the enclosure without a cover? This seems like an awesome way to get the trunk level with the seats folded down in a 2-door.
Slick85
Richard
Austin, TX
How would you compare a sub plus passive radiator setup to two identical subwoofers?
