Mariposap75
Chanelle
South Carolina
Ford Bronco
KeithK
Keith
Ford Bronco
Just checked and the sub has high level inputs so kit 6 should work. I think.
Give the tech number on the website a call, talk to Joe and describe your set up (amps, lci,etc) and he will guide you to the right kit.
Kyrioslol
Talal
Kuwait
2021 4D Wildtrak
Hi everyone! Its my first post here as i await for my Bronco to finish its matte ppf which i recieve on Sunday im looking to upgrade the sound system first thing!
I got 2 Kicker csc4s and 1 csc65. Kicker 200 amp including harness from plug and play along with a hideaway 10in sub. Am i all set with this setup ?
Thanks in advance!
KeithK
Keith
Ford Bronco
Thanks in advance!
Should be. Consider boom mats for the 4” dash speakers, dynamat behind the 6” and rear speakers and if you prefer bass blockers for the dash speakers. I’ve read though the DSP on the amp may adjust for that.
Pugsly
Clayton, DE
2014 Ford Fusion
I just ripped the boom mat out of my kick panel speakers. Made it sound so muddy and hardly any mid-bass.
Pugsly
Clayton, DE
2014 Ford Fusion
What hardware did you use?
I just picked up some small bolts and nylon lock nuts from the hardware store. Nothing fancy.
SoCalG
SoCalG
Southern CA
2022 2DR Bronco BD
Since the front dash speakers are wired in parallel with the 6 1/2" speakers, there isn't a way for DSP technology to remove the lower bass notes for the 4" speakers without removing them for the 6 1/2" speakers. Bass blockers are recommended. The factory dash speakers come with a built in 400 hz filter. So something close would make a difference in balancing the sound.
KeithK
Keith
Ford Bronco
Good point and recommendation.
Synyster06Gates
Austin
Austin, TX
2022 Bronco Badlands Sasquatch
Damn I wish this was in stock. I’m doing all my speakers as soon as the bronco comes in and would like to throw this in too
67BroncoG1
67BroncoG1
Ron
CA
2022 2D BaseSquatch, 1967 Bronco, 2016 Range Rover
Are they the only ones that carry this plug n play harness?
Correct. They make it and sell it directly to the consumer. You might want to call because I found that his online inventory isn't always up to date.
