King Shocks - Available here at Lethal Performance
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Hey All,
We are proud to announce the addition of King Shocks to the 2021+ Bronco Product line up.
If you aren’t familiar with King Shocks already, they are one of the innovators when it comes to suspension technology in off-road racing, making custom shocks for desert racing. Now, King Shocks has grown from a small business building custom made shocks for race cars to a manufacturer of hundreds of products for many different applications. Many of the high performance features available today such as bypass tubes, seal technology, shaft diameters and tube construction were pioneered by King, working to give our customers the competitive edge they need.
King Shocks 25001-392 OEM Performance 2.5 Series Front Coilovers
Ford Bronco King Shocks  - Available here at Lethal Performance 1642632633401
  • 100% Bolt-on Performance
  • 7/8” hard chrome micro polished shafts
  • Aeroquip high pressure hoses
  • PTFE lined rod ends
  • Fully rebuildable and revalveable, and tunable.
  • Made in the USA
  • Larger 2.5 diameter shock bodies increase fluid capacity for smoother, cooler running shocks.
  • Will allow for 35” Tires.
  • Improved reservoir mounts. No more hose clamps
  • Lift: 0"-2" (front)
  • Track Width: Stock
  • Tire Size: 33"-35"
Check them out here below!
W/O Compression Adjuster : King Shocks 25001-392 OEM Performance 2.5 Series Front Coilovers in a Remote Reservoir Configuration (2021+ Ford Bronco 4WD)
W/ Compression Adjuster : King Shocks 25001-392A 2.5 Series Front Coilovers in an Adjustable Remote Reservoir Configuration with a Compression Adjuster (2021+ Ford Bronco 4WD)
King Shocks 25001-393 2.5 Series Rear Coilovers
Ford Bronco King Shocks  - Available here at Lethal Performance 1642632633433
  • Increases wheel travel.
  • Adjustable ride height.
  • Fully rebuildable, serviceable and tunable.
  • Lift: 0"-1.5"
Check them out below!
King Shocks 25001-393 2.5 Series Rear Coilovers in a Remote Reservoir Configuration (2021+ Ford Bronco 4WD)
W/ Compression Adjuster : King Shocks 25001-393A 2.5 Series Rear Coilovers in an Adjustable Remote Reservoir Configuration with a Compression Adjuster (2021+ Ford Bronco 4WD)
Fitment:
BOTH FRONT AND REAR WITH AND WITHOUT COMPRESSION ADJUSTER WILL FIT
2021 4-Door Ford Bronco
2021 2-Door Ford Bronco
Have questions or want to get something on order? Feel free to reach out to me or any one of us on here, shoot us a call at 561-753-8105, or shoot us an email at support@lethalperformance .
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
Logan@Lethal
Logan
Hilton Head Island
2022 Ford Bronco Wildtrak
Great to see other well-known and proven brands joining the Bronco frenzy!
