Larger Tires vs. More Wheel Uptravel
King Luis
Toronto
Volvo XC60 & MK5 Jetta TDI
Could you clarify the loss of height gained comment? You mean with greater articulation and smaller tires?
35" tire is 2 inches. shorter than a 33" tire running on the same suspension. meaning you lose that 2" of clearance.
MadMan4BamaNATL
Ray
Atlanta
With hight? Sorry, I'm not following. I'm not too bright. ?
35" tires get your lowest center of the bottom off the ground higher (the pineapple or differential). That is what's more important to me when wheeling.
also, 35" tires with the Badlands and Sasquatch lift also increase overall ground clearance and improves the angles.
King Luis
Toronto
ok, so if you swapped out those 35s for 33s, still on a Badlands with Squatch lift, you'd be lowering the truck essentially 2inch because of the tire size. but the wheels would have more clearance in the wheel well to move around.
JT1
James
OK
2017 JK Willys
You would only lose half of the height difference, 1" lower and 1" more clearance in the wheel well.
JT1
James
OK
2017 JK Willys
We are all speculating at this point, but someone will figure out an easy way to lift these things and regain the 10mm of lost travel the sasquatch had to sacrifice, or come up with a solution to allow the 315's to stuff (different inner fenders, relocate a component, whatever).
35s in the rocks have a big advantage over 33s. Easier to roll onto a big rock, more clearance under the truck and a massively bigger footprint when aired down. I'd take that over 3/8" extra uptravel all day.
BuckeyeinNV
Matt
Henderson NV
4Runner
This isn't really even a question anymore. I get some people were skeptical before we knew the number - if travel was limited by an inch or more, for example, they'd have a point - but 10mm is not enough to counteract the advantages of larger tires and more ground clearance. Not even close.
glacierbear
Audi RS 7, Ram 3500, Bronco Wildtrak
I am sure that most of the aftermarket manufactures will be all over this bronco. If we take ICON for example I would suspect that adding their UCA and coil overs will probably net around a 30% increase in wheel travel like their kit for the new Ranger. I previously had their UCA's and king coil overs on my canyon and the difference in wheel travel and ride quality was amazing. Hard to fathom that we can buy factory vehicles with 12" of travel and potentially increase that to 15"+ without serious mods.....
Felix808
SRV CA
Up-travel isnt really the thing you need so much. You need ground clearance and droop. For the fronts it wont be noticeable since they are IFS. For the rear the up travel on the offside could slightly impact the droop on the other, but it wont be much. 10mm is less than half an inch, that isnt going to be an issue.
Exactly. When you top off in the upward travel it will start to raise the vehicle giving you even more clearance. 10mm is 1 cm = 25/64 of an inch. Not a lot to worry about. ;)
JT1
James
OK
2017 JK Willys
If ford is already offering a 2" kit, and ICON already has a 0-3.5" kit for the ranger, there are going to be plenty of choices.
Felix808
SRV CA
I have always found that having the least amount of lift to fit the tires you want to run is always best. If I can do that from the factory with warranty intact all the better. While I would like to run 37's, I don't trust the axles for the type of trail work I intended to run & stay reliable. Don't forget about the lower gears in going 35's & stronger axles for anything under the Badlands trim from the factory as well.
JT1
James
OK
2017 JK Willys
Exactly, although I'd bet that 4.70 gears are still ok for 37's with the torque profile of the turbo engines and the available transmissions. 37's on a 2 door would be a nice setup.
MadMan4BamaNATL
Ray
Atlanta
Ohh, you're referring to wheel travel within the chassis? Ok. Sorry, I'm a little slow. Alabama public school education. Ha! ?
broncoenthusiast
iowa
1986 Bronco xlt
Does the 33" tire maybe tuck inside the fender where as the 35s would hit the fender? Thus giving you more than 10mm more up travel with 33s?
hum-vee4us
Donald
Jeep Wrangler
With the Badlands trim you can remove the part of the bumper near the tires, perhaps that's to accommodate more wheel travel from the 35" Sasquatch package.
