Largest tires that will fit on stock base 16 inch rims
Lambeezy
New Jersey
Base 4 Door Bronco
I'm looking for the cheap way out. The stock tires are puny, but I don't want to shell out for a lift right away. I went to a tire spot and they said they need to physically see the rim and the car to determine what size tires will fit.
Any chance I can get 35s? bigger???
ATHIKER
Bill
Toyota Corolla
probably 32" for the stock 16" rim
e90steve
Atlanta, Georgia
Porsche 911
Probably can't get 35's with the factory offsets on the 16" wheel.
PWillette
Parrie
Maine
The narrow width of the 16" steelies may limit what size tire you can mount. TireRack lists several brands of 315/75 R-16s which claim to be 34.6" OD.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I would be very surprised if you got 35" to fit.
But 33" works for sure with no lift or mods required
Lambeezy
New Jersey
Base 4 Door Bronco
Hey do what I just did and you can t go wrong. I found a set of sas takeoffs from a wildtrac with black trim and put them on my base 2 door. NO RUB NO LIFT I only had to remove the crash bars
Ford Bronco Largest tires that will fit on stock base 16 inch rims 0A9BC0ED-6D1D-4D22-8D47-B5A59025CF5D
Those look dope. I never thought about getting used rims, but some googleing shows there is quite the market for them. I can definitely find some bigger rims on the cheap that will fit 35s.
Thanks for the inspiration.
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
285/75R16 are a prefect fit for the base with steelies. Unfortunately the only options are D or E rated. From the D list I’d probably go with the Nitto. Stock Badlands takeoffs would be prefect, C load range 285/70R17 on a decent looking rim.
Ford Bronco Largest tires that will fit on stock base 16 inch rims 79DE95ED-C900-480F-9E6C-3F4650105CB5
My badlands.
Ford Bronco Largest tires that will fit on stock base 16 inch rims 1DB8AE24-761C-41B6-8862-A81C82B4E97B
Will_05
Toyota
33’s on 17’s is what I’m going for on my Base when it gets in next month. Figured I’d change out the steelies, not my style.
Pancho Kornwallace
Pancho
Mustang
What do you mean by "crash bar"? Aren't you worried about losing a "crash bar"? Seems important.
Gnomad
Harbor Springs
Base 2 dr, 7MT EG
Ford Bronco Largest tires that will fit on stock base 16 inch rims IMG_4031.JPG
285/75/16 Dynapro's on the stock steelies. No problems at all, and the gearing seems to be a better match for the taller tires. Rides fine, handles fine, no loss of fuel economy. Corrected the speedo with forscan.
97TJ2Bronco
Asheville
Bad-Base
I called Discount Tire and the guy was emphatic that the 285/75/16's won't work with the base steelies...wtf?
Gnomad
Harbor Springs
Base 2 dr, 7MT EG
The specs call for 7.5" wide and the base steelies are 7". You might have to call around a bit. I used a local Indie to do mine.
