I wanted to add, as of right now it does look like the FE & WT get the black beauty ring and the Squatch gets the warm alloy beauty ring! Maybe the Badlands will have the optional carbonized beauty ring, but according to that preliminary spec sheet it looks like its going to be a 8” rim, instead of the 8.5” rim.I have seen that preliminary sheet from July 14 2020 and it may be correct, if so I stand corrected! Until its confirmed on B&P or until ordering time, I cant assume it’s an option. Also states that the Sasquatch has optional warm alloy beauty ring (where is that in B&P?), I know that they are still working on fixing and updating B&P, so hopefully these options are updated with all 3 beadlock choices.
I have a question for you as you seem to be pretty well versed on the nuances of the different wheel/tire considerations. I am trying to finalize my build, which is either BL or OBX. My question for you is this, if I get the SASQ package with either trim and I find that the 35s are a bit much relative to mph, noise, ride quality, etc., can I shift to 33s when the 35s wear out and need replacement? If so what are the considerations to keep in mind?Truth be told, there is only a tiny chance I'll ever get a Warthog, but 99% change I'll get a Badlands w/33s.![]()
Why do you believe these prices will go up?This board will explode if your side note is true. It does make sense though.
Because their early surveys indicated the price for V6 would be higher, and all other options are exactly priced at what the survey said.Why do you believe these prices will go up?
I understood that Badlands gets 4.7 in the rear and badsquatch adds 4.7 in the front. (Because I'm getting manual BL)You can select 4.7 gearing on Badlands without going Sasquatch.
they still make phone books?It's really only about an inch higher. Sitting on a phone book will give you that.![]()
This is to soften the possible sasquatch tire shortages.Took some photos of the wheels at super cel east. Left is the optional BL 33" Goodyear MT on optional wheels. Carbonized ring. Looks like ring comes off but I don't know if it is beadlock capable. (I don't know anything about beadlocks.)
I like the optional wheel but I haven't decided on paying the extra $995 yet. I'm staying with the 33" Ko2's.
Right photo is Sasquatch 35" on Sasquatch wheels. Silver ring
Where are you getting this? Didn't a Ford engineer say it was 10mm?It's not a contradiction. Badlands has 4cm more suspension travel than Sasquatch.
Gotta be 10mm. 4cm is illogical.Where are you getting this? Didn't a Ford engineer say it was 10mm?
Obvious one is resetting speedometer. I guess the dealership can do this.I have a question for you as you seem to be pretty well versed on the nuances of the different wheel/tire considerations. I am trying to finalize my build, which is either BL or OBX. My question for you is this, if I get the SASQ package with either trim and I find that the 35s are a bit much relative to mph, noise, ride quality, etc., can I shift to 33s when the 35s wear out and need replacement? If so what are the considerations to keep in mind?
Hearsay. Look at Bronco prelim specs doc.Where are you getting this? Didn't a Ford engineer say it was 10mm?
You are correct! A Ford rep previously stated in a Q & A that the Squatch package is limited 10mm (which is merely 0.3937”) over the standard BL susp because of tire size.Where are you getting this? Didn't a Ford engineer say it was 10mm?
