Paint
Jack
Oklahoma
Tundra
Ford Bronco Leaked pics: IFS, 7spd manual shifter (w/ crawler gear), sway bar disconnect, top latch, EcoBoost engine, AUX switches, front & rear lockers! rd-bronco-manual-transmission-7-speed-1024x924-
Ford Bronco Leaked pics: IFS, 7spd manual shifter (w/ crawler gear), sway bar disconnect, top latch, EcoBoost engine, AUX switches, front & rear lockers! 2021-ford-bronco-2-3-turbo-engine-i4-1024x840-
Ford Bronco Leaked pics: IFS, 7spd manual shifter (w/ crawler gear), sway bar disconnect, top latch, EcoBoost engine, AUX switches, front & rear lockers! bronco-switches-1024x634-
Ford Bronco Leaked pics: IFS, 7spd manual shifter (w/ crawler gear), sway bar disconnect, top latch, EcoBoost engine, AUX switches, front & rear lockers! 021-ford-bronco-disconnecting-swaybar-1024x682-
Ford Bronco Leaked pics: IFS, 7spd manual shifter (w/ crawler gear), sway bar disconnect, top latch, EcoBoost engine, AUX switches, front & rear lockers! ord-bronco-bilstein-shocks-suspension-803x1024-
Ford Bronco Leaked pics: IFS, 7spd manual shifter (w/ crawler gear), sway bar disconnect, top latch, EcoBoost engine, AUX switches, front & rear lockers! ord-bronco-removable-top-center-latch-1024x885-
Ford Bronco Leaked pics: IFS, 7spd manual shifter (w/ crawler gear), sway bar disconnect, top latch, EcoBoost engine, AUX switches, front & rear lockers! -ford-broco-removable-top-front-latch-1024x657-
Ford Bronco Leaked pics: IFS, 7spd manual shifter (w/ crawler gear), sway bar disconnect, top latch, EcoBoost engine, AUX switches, front & rear lockers! 2021-ford-bronco-dashboard-4wd-knob-914x1024-
Ford Bronco Leaked pics: IFS, 7spd manual shifter (w/ crawler gear), sway bar disconnect, top latch, EcoBoost engine, AUX switches, front & rear lockers! bronco-upfitter-1024x438-
Some notes by @prendrefeu
Notes:
  • 7 speed manual (1 speed is CRAWL)
  • 4cyl w/ Turbo - and manual as a possibilty
  • Front Sway Bar Electronic Disconnect
  • 34"-ish tires as standard, most likely.
  • Bilstein-designed shocks w/ reservoir.
  • Independent front suspension
and more.
JimmyDean
Louisiana
82 Bronco, 513 ci; 71 mach 1, 351C; 06 F-250, 6.0; 56 800, 172c.i. gas
And the 6-speed manual with the Crawl speed right below Reverse - which I like. I wonder if C will work for the Mall Crawl? ;)
that is the gear you use for driving through the parking lot at high RPM impressing all the 'Bro's'.
JimmyDean
Louisiana
Ford Bronco Leaked pics: IFS, 7spd manual shifter (w/ crawler gear), sway bar disconnect, top latch, EcoBoost engine, AUX switches, front & rear lockers! 1591814665567
I really like the switch setup, seems that they worked to make it weatherproof as well, which is good.
Superds
ND
I like the articulation mode button on the left. Must be for the hydraulic fluid ride height system.
JimmyDean
Louisiana
pretty sure that would be for swaybar disconnect
Nickp
Nick
Phoenix
What’s weird is it’s definitely an IFS.... but showing a huge amount of flex. Very interesting...
JimmyDean
Louisiana
mmhmm. I am intrigued by that button, I could think of a few other emblems I would use for swaybar disconnect...so that could be something more...interesting.
Superds
ND
I also recall someone saying a while ago it’s wasn’t going to have sway bar disconnect. That icon could go either way in my opinion.
Paint
Paint
Jack
Oklahoma
Tundra
That is one tall ass spindle.
Also...Is that some sort of composite or carbon fiber roof panel?
Toyhoarder
The west
Early Bronco, F-150, F-450
I hope that button is for a sway bar disconnect or “articulation enhancer” as eluded to above.
I don’t see a button for the “dig/turn enhancement”. That graphic wouldn’t make sense for that feature.
Paint
Paint
Jack
Oklahoma
Tundra
This is what a sway bar disconnect looks like, and this is a pic of the Bronco:
