Do you have a kayak ? Do you only tie it to the roof racks that Ford added or is there something else I can't see ?
So how does the kayak hold on the roof ? Are those roof racks the one that Ford added or aftermarket ? Do you have j racks on you just literally put the kayak on the roof racks with some ratchet straps ?
Where did you get those exact rims . They look mad niceIt's actually a thick 4-door molding that will stop any door ding!
Just the canoe. And it’s the factory roof rack. I did move the cross bar to the forward spot. And strapped her downDo you have a kayak ? Do you only tie it to the roof racks that Ford added or is there something else I can't see ?
How does she handle with the canoe ? Any swerves or something . I have a kayak . My bronco that should arrive around July 9th comes with the factory roof rack. So if I just mount the kayak on the roof rack and strap it down with ratchet straps I should be good right ?Just the canoe. And it’s the factory roof rack. I did move the cross bar to the forward spot. And strapped her down
This is how I see it most the time, parked at the airport.... It still badass!!!I’ll start it off!
Yes! It took me a couple of tries to get the strap placement right, but it doesn’t budge. I haven’t been above 65 mph yet, but I did go down a pretty bumpy dirt road and it was fine.How does she handle with the canoe ? Any swerves or something . I have a kayak . My bronco that should arrive around July 9th comes with the factory roof rack. So if I just mount the kayak on the roof rack and strap it down with ratchet straps I should be good right ?
It's the Factory Rack from Ford, and just used Ratchet & Lash straps. I just picked up soft loop to fasten around the rack to use as anchor points for the Ratchet Straps. And the kayak is just flat on the rack.So how does the kayak hold on the roof ? Are those roof racks the one that Ford added or aftermarket ? Do you have j racks on you just literally put the kayak on the roof racks with some ratchet straps ?
