Here you go. Really focused on the heavier trims and 4 dr, making my way from the heaviest trim down. The number of things Ford lockouts per trim tells us the order of the heaviest trims. So I ranked them based on what’s locked out...then you could see my estimated weight lookup for those trims which corresponds to the second chart.
just messing around making sense of what information we have to put the pieces back together. So don’t by any means hold me to this stuff. But one thing that’s obvious is the ranking of trims based on lockouts.
it seems to me, we could get manageable 800-900 payload with the GVWR cap for most of the heavier 4 drs, with the exception of badlands and black diamond. The path of least resistance to fix this is for Ford to change the steel bumpers to another type of metal as a quick fix in 2022 for those specific trims. That’s my prediction for 2022.
spot checking 2.7 non Sas BL, and OBX. Pretty close. Also including assumptions for added armor
As far as my build goes. I’m steering way clear of the 2.7 non sas BL 4 door. Could either go 2.7 OBX with 33.2” tires and steel bumper (to give appearance of lift). But what I’m estimating is that those E load tires plus gearing plus steel bumper and bash plates puts me at about the same weight as an OBX sas with no steel parts given 35s are C load and only marginally heavier than my 33s upgrade on the non sas.
So in between those two builds. Really glad I did this because the numbers really do imply that getting an inbetweener 2.7 non sas BL is going to bite you in the ass when it comes to payload.
Going to test drive a Raptor this weekend with the wife. It looks to have the same step in height, and of course C load 35s (but ko2).
In summary, the armor really messes you up here. So be careful if you’re choosing some type of BL or BD build as a family hauler. Just my recommendation
