Hey guys, why would I want the 4.7 rear axel over the 4.46? What benefits dose the 4.46 have over the 4.7? Any And all thoughts are welcome. I’d like to hear benefits and downsides to both axel sizes.
Explain what you mean by more “Mechanical advantage”. I’m trying to decide if I want to spent the extra $$.4.7 would have more "mechanical advantage".
This is helpful!Do you live where there's large hills or mountains? Do you ever plan on going to 35's? Do you ever plan on towing a trailer or loading your Bronco heavy? If you said YES to any of these things then you want the 4.7
Downside is that at highway speed you turn a few hundred RPM higher.
I'm going to guess what @Beachin 74 is saying before he posts, it's a choice between Fuel Economy vs Performance.Explain what you mean by more “Mechanical advantage”. I’m trying to decide if I want to spent the extra $$.
The ratio is how many times the driveshaft turns for 1 revolution of the wheel/tire. It would be easier on the drivetrain with the 4.7 than the 4.46 by just a little bit.Explain what you mean by more “Mechanical advantage”. I’m trying to decide if I want to spent the extra $$.
I'll start by saying that I have no experience with this Ford 10-spd auto or the new manual transmission, but from looking at the overdrive on them, they're nearly the same at around 0.65. I'm inclined to think that it will indeed be used at speeds above 65 mph and that'll affect gas mileage some, though not more than a 100-150 rpm difference from 3.73s to 4.27s, maybe 200 rpms for 4.7. I'm guessing here but from a background with car gearing and older 2000s) Ford transmissions. Hell, if someone up sized their wheel diameter with new wheels and tires it could negate the gearing anyways but I'd have to do the math on that.There is a bit of misinformation in this thread. I don’t think the 4.7 axle gearing will *necessarily* change the fuel economy number people care about; highway MPG’s. The 10th gear on the auto trans is so tall, my guess is that you’ll only ever been in 10th gear if you are on perfectly flat highway with the 4.7 gearing. With the lower gears, especially the 3.73, and the 32” tires, I would bet 10th gear will be basically unused. (It sounds like the ranger does use 10th gear pretty handily based on what I’ve read, but the ranger runs 255/65r/17’s which are a decent amount smaller and lighter than the 265/70r17’s that are on the 3.73 equipped Broncos. Base notwithstanding)
Where the 4.7 is going to be killer is in city driving since it will accelerate so much faster. YMMV.
