- Jared
- Jul 14, 2020
- 210
- 1,253
- 1,858
- South Florida
- Website
- www.lethalperformance.com
- 2020 First Edtion 2.7L / 2020 Shelby GT500 CF
- Raptor
Hey All!
This AMP BOV Adapter from UPR will allow you to vent the hot boost to the atmosphere instead of recycling it and creating much hotter inlet temperatures. Our Blow Off Valve Adapter is a simple bolt on with an allen wrench and about 15 minutes to squeeze your hands in the front passenger side of the engine bay to install this Awesome sounding little upgrade.
- Show Quality Finish
- Black Anodized finish
- Easy 15 Minute Installation
- High Quality CNC Machined Billet Aluminum
New Design includes both fine thread and coarse thread hardware
Check out how it sounds here below!
Installation:
Installs in 15 minutes or less
1. First locate the Blow Off Valve in the front passenger side engine compartment
2. Disconnect the power wire to the Blow Off Valve
3. Now disconnect the BOV hose to the bypass
4. Remove the 3 bolts that attach the BOV to the flange
5. Now you will have to rotate the Blow Off Valve Adapter in place.
6. Note: The factory holes are spaced to only allow the Blow Off Valve to be installed one way.
7. Lightly oil the threads on the supplied bolts. Do not over tighten.
8. Once you have tightened all the bolts and install the factory hose and electronics your set.
Check it out below!
Black Finish
AMP 85500-01 BOV Blow Off Valve Adapter - Black (2015+ Mustang Ecoboost / 2019+ Ford Ranger Ecoboost / 2020+ Explorer ST / 2021+ Bronco 2.7L , 2.3L)
Silver Finish
AMP 85500-06 BOV Blow Off Valve Adapter - Silver (2015+ Mustang Ecoboost / 2019+ Ford Ranger Ecoboost / 2020+ Explorer ST / 2021+ Bronco 2.7L , 2.3L)
Have any questions or concerns? Let us know! Reply here, shoot us a call at 561.753.8105, or shoot us an email at [email protected].
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
Installation:
Check it out below!
Black Finish
Silver Finish
