- ron
- Jun 30, 2021
- 3
- 505
- 702
- new orleans
- Toyota Tacoma TRD Off Road, Fiat 124 Abarth
- Base
- Banned
- #16
the ending 6 digits of a vin are a sequence for production. the first 11 digits are specific across the make. here is a link of how ford has their vin structured.VIN's also typically *can't* increase strictly numerically, usually because of that nifty digit in the middle of the VIN, the check digit. For most manufacturers, the check digit is there as a function of a predetermined algorithm to prevent against VIN fraud, and to ensure that the VIN can *only* have come from the factory itself. i.e. simply increasing the digits in the last 6 without knowing what the check digit would need to come out to, leads to an invalid VIN.
tl;dr there's no rhyme or reason to VIN's, the monthly numbers show 800-ish for June, hopefully July is better.
Yes. I read it. Yes, it has check digits. Yes check digits are for validating VINs, yes they change inside every VIN dynamically.the ending 6 digits of a vin are a sequence for production. the first 11 digits are specific across the make. here is a link of how ford has their vin structured.
*2021 VIN Guide (ford.com)
the (1fm) you refer to refers to the united states ford motor company. (wpo)is for germany porsche. (5te) toyota fremont california.The only numbers that make sense to me is that this being a 2021 model, the only “1” in my sequence is the first digit. So, that might signify the year. Next, my build is scheduled for August. The only “8” is the fifth digit from the left. So, that might be the month.
nope, it won't get you your truck sooner, but it might help to figure out when it will get to you.... but wth, i have not heard a single reference to a wrinkled rear window on the soft tops for this entire thread...Yes. I read it. Yes, it has check digits. Yes check digits are for validating VINs, yes they change inside every VIN dynamically.
The real question to ask yourself though is "will this get my truck here sooner?" And that answer is still a resounding no.
There is absolutely nothing to figure out. This information is publicly released by Ford at the end of every month. It was a little more than 7,000 at end of June.
@Razorbak86 posts it on this forum every month.
https://www.bronco6g.com/forum/thre...h-initial-bronco-sales-production-data.18697/
My VIN is ends in 72497, which I received on 04/22 with a build date of 06/21, then it was pushed back to 07/12, then to 08/02, and now with a build day of 08/06. I have not been issued a window sticker, but I have my fingers crossed!My 70035 was in the second wave of VINs and is scheduled for next month. They most certainly will not build 70k before then.
