Yes - the woolly bear comes pre-wired with power…so in the main field kitchen area you get a couple USB ports and a 12V outlet…and a few switches for storage compartment LED lighting and underbody lighting. This is all powered off a Group 24 battery stored in the battery compartment at the front of the trailer. The battery is charged via your 7pin trailer connection to the tow vehicle…but can also be charged using solar panels that can plug into an Anderson jack that is located on the front of the trailer. The sliding drawer compartment on the back also comes pre-wired with a 12V outlet so you can plug an electric cooler in there.Would love to know more about your setup inside the trailer - do you have electrical? The Woolly Bear seems like a great value.
While all of that is nice and does a good job, you’ll likely need additional lighting for when you are cooking and doing other things around the trailer….I have a few rechargeable magnetic LED lights that I can attach to basically anywhere on the trailer or my bronco.
