Listen ford engineers ZF-5 speed with 2.7 bronco
Orangeinthebarn
Joe
Tennessee
2016 z71, 1992 bronco, 1977 F-150 4x4
Ford,
If there is a way you can fit the ZF-5 speed from the 1990’s F250 with the low granny gear it would be a huge success with the 2.7 engine
Advertisement
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
They'll have an aftermarket solution by the end of next year
NCOBX
H2 Hummer, Holden Commodore
Most people aren't going to void a warranty to put in an aftermarket transmission. Only the 1% wealthy and sponsored YouTubers will.
It’s not going to be in warranty forever, and wealthy people shun manuals as we can see from their availability(or lack there of) in ultra high end cars.
BroncoHooves
Austin, TX
After warranty expires, I will do anything to the vehicle and do my own work on it.
Imissmy1996bronco
1st gen 2.7 eco f-150
The zf5 actually has a lower torque rating than the 7 speed... (for the st-42, the s5-47 is barely higher than the 7 speed), also the zf5 has worse low gears than the mti550.
The reason the 2.7 isn’t being offered with a manual is because ford expects these engines to be tuned, and a mildly tuned 2.3 will still be within that rating, while a tuned 2.7 will quickly exceed it. The 2.7 is also not offered with a manual transmission anywhere, so it is not set up for it, and doing so would require changing/modifying the engine design. Couple this with the fact that manual sales aren’t going to be very many in the grand scheme of things, and there is not enough incentive for Ford to justify altering that engine’s production line, and adding another variant.
OC4x4
Oregon City
Avalanche
I might be stating the obvious here, but when I heard Ford was reintroducing the Bronco, I had visions of the glory years of 1969 to mid 70's, with a v-8 and manual transmission....love the sound of a V-8 with an aftermarket cam and headers. At least that's what I envisioned with the retro styling, but with modern safety and tech. Don't get me wrong, I think Ford has done a fantastic job with the new Bronco, its just a different driving experience.
NCOBX
Half the fun of it was shifting through the gears hearing that amazing engine note.
Now you can listen to the weed eater noises while shifting.
Flourman
Centennial, CO
2017 F150, 1987 Jeep YJ, 2019 Beta 300RR
ZF’s are a mile long and have an integrated bell housing. I don’t think they’d make a special case for a sub-par transmission with a long throw. Maybe for a 4-door but a 2-door you may as well direct couple the t-case output to the rear axle. I’ll be extremely happy with a short throw manual. But I’m coming off driving T18’s and ZF’s most of my life.
Advertisement
Advertisement
