Several things you can make yourself to make the tie rods stronger.
1. Get a piece of heavy wall pipe, cut it length wise and place over the tie rod. Take three or four hose clamps to hold it together. Hose clamps are a lot stronger than you think
2. See if a piece of square tubing that will fit over the tie rod. If so cut it length wise. Weld some tabs on each half, then drill holes through the taps. Place bolts through the tabs and bolt the halves together
3. If you don't have tools and/or no skills get a piece of angle iron and some Gorilla brand duct tape and use that.
