Long travel rear suspension
JPG
JPG
Montreal, Qc, Canada
Bronco Badlands
Coilovers are for the front though. The long travel i was talking about is for the rear. Or are they coilovers front and back?
BAUS67
redneck
Central PA
4 Coilovers.
rsmtracker
14 RAM 1500 Crew Cab, 18 Jeep JKU Sport S
Just a technicality, but to be accurate the Bronco has coilovers which are the coil and shock in a single unit, and can or not include the bump stop. Technically, a strut is an integral part of the suspension links, where the shock is combined with a link/links to locate the axle.
And yes, coilovers are going to be more expensive than a separate coil and shock. A benefit though is better packaging. Also, with a coilover there is always a bit of preload on the spring so the spring doesn't unseat, where with long shocks and a separate spring the spring can unseat when the axle droops out all the way. Really, while a bit more expensive, the coilover is a better way to do it.
I prefer to refer to coilovers to the ones you can adjust, for reference to what i have in my 14 RAM 1500 crew cab truck
2021-01-17_06-17-50 by RAM RSM, on Flickr
But yes you're right i guess technically i need to refer to the Bronco suspension setup as factory coilovers though secretly i'll call them quick struts , at least in the front as the strut is connected to the LCA :)
Aftermarket adjustable coilvers have more benefits as you have indicated no doubt, way more expensive than conventional shocks with separate springs, little more expensive than race shocks + separate springs, but if you're looking for performance the race coilovers is where is at.
goatman
Richard
Bakersfield
A bunch of Jeeps
Ford Bronco Long travel rear suspension 50847428377_3d5876005c_h
Every vehicle with IFS has the coilovers attached to the LCA. Like side by sides and Trophy Trucks and Class One buggies and Ultra4 cars and....and...and...
A coilover is a coilover. :)
