Looking for feedback - Oracle Bi-LED vs Form Lighting vs OEM signature
WildtrakBronco
Pennsylvania
2022 Bronco
Greetings!
I am hopeful to gain some feedback from others who have gone through headlight trails. I, myself, swapped my OEM signature LED headlights out for the Form Lighting quad-projector LED ones earlier this year. Since doing so, I am appreciative of the focused light output and crisp cutoff the projectors provide, however, I can't help but wonder how these compare to the Oracle bi-LED projector headlights.
Aside from the actual light output of the Form Lighting, I have some personal preferences about them. I don't much care for the animation; this is both the sequence when you first turn the vehicle on as well as the dynamic turn signal. In comparison to the OEM signature look, which was cleaner, and I wish I could have kept that style. The Oracle lights look like that have the clean halo light around the headlamp again and a 'normal' blinking signal indicator.
If you have gone through these lights, and in particular have the new Oracle bi-LED ones, please give me some feedback. I'd like to gain insight before I take the plunge on them.
Many thanks!
OracleLights
New Orleans, LA
www.oraclelights.com
The Oculus headlamps deliver exceptional driver visibility with powerful, focused LED light output, giving you a clear and well-lit path ahead. This complete headlight replacement is designed with a high-precision cut-off line, ensuring bright illumination without causing glare or blinding oncoming traffic—perfect even for lifted Broncos. Experience safer, more confident driving, day or night.
Check out this wall test photo!
Ford Bronco Looking for feedback - Oracle Bi-LED vs Form Lighting vs OEM signature Bronculus_Wall_Test_2_1080x776
WildtrakBronco
WildtrakBronco
Pennsylvania
2022 Bronco
Thank you! That looks like a crisp cutoff and nice light output. Is the adjustment easy on these? do they adjust just vertically or horizontally, too?
OracleLights
New Orleans, LA
Adjustment is very easy on those. The adjustment is mainly up and down.
BizJetTech
Adam
Stuart, FL
2024 Bronco
Greetings!
Aside from the actual light output of the Form Lighting, I have some personal preferences about them. I don't much care for the animation; the is both the sequence when you first turn the vehicle on as well as the dynamic turn signal. In comparison to the OEM signature look, this was cleaner and I wish I could have kept that style. The Oracle lights look like that have the clean halo light around the headlamp again and a 'normal' blinking signal indicator.
Many thanks!
Agree with you - following as I hope some people with the oracle Bi-LED chime in here
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Greetings!
Many thanks!
In our personal tests the Form Lighting puts out a lot more light. The Form Lighting output does not vibrate either with the engine running. The Form Lighting lights are a solid 1-piece design whereas the other lights ship to you unassembled and you have to mount multiple plastic mounting tabs to it which causes the lights to bounce around.
23BDBigSean
Sean
Dallas,Tx
2023 Bronco
I
Ford Bronco Looking for feedback - Oracle Bi-LED vs Form Lighting vs OEM signature IMG_9182
i have the oracle Bi led headlights. I like them. I had the Amber/white switch back at first but swapped them out for the Ambers.
Very bright, often have people flashing their brights at me lol
I like that I can change from just the halos to the Halos with the Amber turn signals without having the bright centers on.
I was going for the raptor look with the Amber head lamps so this was the closest I could find to emulate that look.
23BDBigSean
Sean
Dallas,Tx
2023 Bronco
Ford Bronco Looking for feedback - Oracle Bi-LED vs Form Lighting vs OEM signature IMG_8614
WildtrakBronco
WildtrakBronco
Pennsylvania
2022 Bronco
We advise Form Lighting as they're our partner brand.
I am going to stick with my Form Lighting setup. After doing some exhaustive online research, there are a number of instances where the Oculus bi-LED setup appear loose and wobbly. Enough to shy me away from them anyways.
I also take into consideration the general silence in this thread and inability to find many others on this forum that have gone the Oracle route as a sign.
I'm just using the data available to me and drawing my own conclusion. Other people's experience and mileage may vary.
chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
Its really hard to beat any of the headlight upgrades out there. The biggest thing I feel you are looking for is support and I feel Form & Oracle will have better support and service than any other brand out there. With that said I think the Forms look better and from our tests do edge out Oracle on output.
We have both options on sale for Black Friday! Feel free to hit up @Caleb@PandaMotorworks or myself with any questions or help ordering!
Coryshad
Cory
Ninocobg*12
24 Badlands MT
For what it’s worth, I had oracles on a gladiator. While they weren’t ever wobbly on that platform, they did have a tendency to overheat and shut off during extended periods of slow moving ie. off-roading :facepalm:
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
Any chance we’ll see Elite headlights for the Bronco in the future?
It would be a great offering to bring to the market but no confirmation on the next set of Elite Series headlights from Diode Dynamics.
Hotshot Offroad
Hotshot Offroad
MT
2023 Bronco
This is a great plan. Nothing against Oracle; but their headlights seem to have that bad wobble effect for a lot down the road. Form has been proven to hold strong and perform very well. We sell a lot of Form lighting and the Bronco headlights are up ticking too. You made a great choice!
