Do you have the complete part number for the rectangle piece?Yep. Everything with a yellow square next to it.
Do you mean the 12B523?Do you have the complete part number for the rectangle piece?
4 door is what I need, much appreciated.M2DZ-7813010-AA
That's 4 door, if you need 2 door let me know and I'll look it up
Yes, that oneOr do you mean the 12B523?
NOZ-58132K23-AYes, that one
So it was strictly metal underneath and the Dynamat went in without much trouble with the added bulk of the mat?I installed Dynamat underneath my vinyl flooring.
The Vinyl Flooring I ordered came with the rectangle piece.Do you have the complete part number for the rectangle piece?
HX1 is listed as a retainer clip, but it has a yellow square, so it should’ve come with the vinyl floor.The Vinyl Flooring I ordered came with the rectangle piece.
But @Ducati1098 what are those turquoise pictured pieces? fasteners?
( HX1, HN1, HM1)If so can you send the part #'s and qty of which are needed?
Would I need that for the installation of the vinyl floor?
Ok, I'll check this weekend, the box is giant and behind tons of Bronco parts waiting on my build. lolHX1 is listed as a retainer clip, but it has a yellow square, so it should’ve come with the vinyl floor.
HN1 is a push on (I’m guessing, plastic) nut. The carpet floor has the same one so should be able to be reused.
HM1 is just a push pin. Once again the carpet diagram shows it also, so you should be able to reuse it.
