- Oct 16, 2021
- 7
- 39
- 7
- Monterey, CA
- 2021 Ford Bronco Big Bend
- Big Bend
How tall is the security drawer?
We've debated doing that... The concern will be the 150lb downward weight on the brackets. knowing how roof issues have been, not sure if they would cause an issue on the top part of the roof seam since they are not bolted in or how the brackets will hold up with their integrity (although brackets seem stout enough)... guess we'll have to try it out eventually... I mean its only a roof replacement needed if it doesn't work outQuestion on the Garage Hoist, can you use the straps thorough tue Roof rack ? That would be awesome to just do some kind of quick hooks or connect/disconnect system.
Thank you for the replay, I would probably do a test stress run and leave it overnight about a foot over and air mattress or something lol.We've debated doing that... The concern will be the 150lb downward weight on the brackets. knowing how roof issues have been, not sure if they would cause an issue on the top part of the roof seam since they are not bolted in or how the brackets will hold up with their integrity (although brackets seem stout enough)... guess we'll have to try it out eventually... I mean its only a roof replacement needed if it doesn't work out
no drilling, shelf fits perfect in slots on top. Stays put with top on.Awesome build! Is your DIY shelf secured with anything &/or requiring drilling into anything ?
