mrnoodley
Toms River, NJ
2012 JK, 2018 JL, 2020 Gladiator, 2021 2dr Badland
I'm most curious to find out if they still have the welded ring gear on these units. As-is, there are limitations on what you can slap in there.
@Rocketeer Rick had a much better and technical understanding of what would be needed/required, i'm still on the uphill slope of having to learn/remember the details on this.
None of the locking diffs have welded ring gears. All non locking diffs have the welded ring gear.
SPITmadFIRE
CA
All Badlands have the M210 locking front diff, sasquatch or non. 4.7:1 gearing in a non-Sas would need to be a manual transmission IIRC. That's what I have sitting on DirtMtn...
Yeah, I remember seeing the gear ratios for the rear locker change automatically when switching between 7MT and 10spd options, but didn't recall if it was displaying the front ratios as well. A non-squatch Badlands with the 7MT should be 4.7:1 all around then?
vrtical
Doug
GSMNP, TN
Fords
yup your not gonna have mismatched F/R gearing.
jjack50
Jack
Temple, NH
2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
and when they are done upgrading they will hate themselves for not ordering from the factory to begin with.
It only makes sense to upgrade to 5.13 and 5.38 as it did not come from the factory with these gear choices
Not true. If I buy a Black Diamond because that’s what I want with the 4.46 gearing and I want a front diff lock then this is perfect. I’m sure it can be setup for less than $6000 so that’s good. Not everybody wants or needs to run the biggest tire for technical rock crawling.
Raptor911
Raptor911
Broadlands, VA
I never said one needs big tires for technical rock crawling.
dgorsett
colorado
F250, Mustang, Explorer
We saw this in the Ford performance listings some time ago, but a good refresh. Of note to some (me included) this set up is not available for the 4.27 ratio :(
ezapar
Seattleish
23 Wildtrak LUX
Wow!
That's actually really cool that they offer it after market. The guys ordering base and lower trims without Sasquatch have a LOT of upgrade paths now.
Yes. But imagine the total cost. 1800 bucks plus an install. Per axle. No warranty offered. Might as well Squatch it.
Theherofails
Thomas
Phoenix
Yeah, but you can find Ford Performance stuff heavily discounted at other vendors. I got my ARB compressor for much less than Ford was offering (for example), and the Ford Performance tune for my Ranger was about half the price at a local shop.
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S
This. I don’t like the Badlands grille or signature lights. I definitely don’t want Sasquatch in winter. If I find the front locker is needed I can install myself. Wiring is easy if you don’t care about integration with the GOAT modes. I don’t.
Snappy22
NJ
2013 Honda Pilot, 2022 Bronco BD
This is great! I assume no one has seen a video of a hero switch being added? Just replace the whole assembly with a new one containing the extra switch?
HPNQ420
Wauwatosa, WI
I am not sure if you can do a hero switch but normally an e-locker just needs 12 volts to engage so any 12 volt switched power will do.
mpeugeot
I would rather have a Torsen that bolted in the M190, it would solve the vast majority of what I would want/need without having to go to the M210. If you need the M210, then you should definitely consider the Sasquatch or the Badlands. As others have said, it's a great bang for the buck.
MrJoe
Joe
Southern Maryland
'73 Bronco (sold), '99 Ram, '08 Explorer, '16 CMax
Exactly. I'd like the locking diff and keep the smaller tires.
Rocketeer Rick
Rick
Rochester, NY
2013 F150 STX 5.0L, 1999 Mustang Cobra
Unfortunately, Ford throws a wrench in the works by welding on the ring gear of all M190 axles. So, even if you buy a Torsen, you'll still need to swap out the ring and pinion gears. Probably still cheaper than swapping in a 210, and all that entails, but not as clean as it could be...
