Mabett 6.5" Rear Speaker Pods Available Now!
reigny
Karen
Delray Beach, FL
Ninja 650, 2003 Honda Shadow Ace
I installed my Mabett 6.5” pods & speakers today. My observations:
1.) These make a big difference over the 4” speakers.
2.) They fit 6.75” speakers. I used Kicker KS 6.75” and they fit like a glove.
3.) Easy to install, but still takes some time. Allow an hour.
4.) Can be installed without removing the hardtop. You just have to use the 90 degree bronco Allen wrench that came in the tool kit and remove the two screws closest to the top of the roll bar instead of the other two screws further down like the instructions say. Then once you get the pods off you can easily transfer over the brackets. It certainly would be easier to remove the hardtop, but maybe save the trouble if you want.
No. Kicker 47KSC6704 KS Series 6-3/4" 2-way car speakers.
Here it is! I think i'm going with these for the back as long as its confirmed they fit.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Yep. They fit the speakers I mentioned in my post. BIG difference in backseat sound.
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
I went with 6.5's... they still fit correct?
reigny
Karen
Delray Beach, FL
Thank you! I listened on crutchfield and debating these or the 6.5”.
negativezero
Brad
Dallas, TX
Toyota Tundra
6.75 vs 6.5" is only like 7.8% more surface area, but it's not going to sound 7.8% better. I imagine the differences are near negligible, particularly if they're not driven by a sub and/or played approaching max wattage.
Toffen
Rick
Halifax, Nova Scotia Canada
2010 Jeep Wrangler 4 door
Never mind that they are 50% more $.
Will they sound 50% better?
edited for my bad math!😜
nwGTS
Nate
Chicago, IL
False. I have proven it is, in fact, 8.1% better. The value is there. /s
nwGTS
Nate
Chicago, IL
Never mind that they are 30% more $.
Will they sound 30% better?
??? Same cost on Amazon and Crutchfield for the same series 6.5 or 6.75.
nwGTS
Nate
Chicago, IL
reigny
Karen
Delray Beach, FL
So are the KS worth it or not??🤦‍♀️ Sounds a lot better in crutchfield sample.
negativezero
Brad
Dallas, TX
Toyota Tundra
ETA is Sunday delivery, so I'll be back here to relay details (unless someone else beats me to it).
Whelp y'all, Amazon dropped these off a bit earlier and I'm quickly back here with early feedback.
The good news? I think these work for the 2-door without headache or modification. I uninstalled the driver-side OEM pod and dry-fitted the unloaded new one with loose screw-ins. So that's looking good. They're not done yet, so I am still prepared for a headache.
Great news #2: You don't have to have your hard top off for this one. All 6 bolts that hold the pod in place are T30 bolts. For some reason, my Bronco toolkit T30 bit was just a hair too big to fit, but a quick trip to the hardware store and a 1" shank T30 bit later, the bolts are out without even a scraped knuckle.
The uninspiring news? These clips are somehow more fragile than my ex-gf's ego. I couldn't have been more caring and gentle (with either), yet somehow after lovingly prying the face off of the speaker pod I was greeted with a broken clip bouncing around inside the pod. I'm used to small details handwork, and I don't know how I could have treated this thing any gentler. Oh well.
Oh - and if anyone is curious about a 1-1 size comparison with the OEMs? I'm thinking ahead for y'all. Enjoy the "I only have X minutes to complete this before the rest of my weekend schedule impludes" shoddy boom mat work for the Infinity Reference speakers I've had in for a while.
Ford Bronco Mabett 6.5" Rear Speaker Pods Available Now! IT8wypH
Careful buyer FYI: The quick connectors are bare wires, so if you want a clean plug then be ready to have those on hand. Most established speaker brands provide their own connectors, so if you're buying quality this is only a splice job between both bare sets.
Visually:
What's provided is the system quick disconnector (left wire set), which has the plastic that clicks in at the top, and that ends in bare wire. White is POS, brown is NEG. The right wire set is what was provided by Kicker. The wire terminals slide right on the back of the speaker, and bare wire at the ends too.
Ford Bronco Mabett 6.5" Rear Speaker Pods Available Now! hqhsHo5
Enjoy my hilariously bad soldering here, trying to splice these two wires as stable as possible:
Ford Bronco Mabett 6.5" Rear Speaker Pods Available Now! a5LPFO8
And for cleanliness and durability (and hiding that disaster of a soldering job), heat-shrink over the splice.
Ford Bronco Mabett 6.5" Rear Speaker Pods Available Now! WrHTjVF
Side-by-side of the actual pod with speakers in:
Ford Bronco Mabett 6.5" Rear Speaker Pods Available Now! gUOruGL
As the red text indicates, if you're installing 6.5" Kicker CS's, leave that speaker cover off. The Mabett lid doesn't close if the speaker cover is on. I'm sure that's probably already well known, but I didn't know it.
EDIT 2 - 7:15pm - after installation
Results are in... 2-door owners buy with confidence. This fits the 2D very well!
Immediate improvement in sound (non-B&O) - better volume and mids. Tomorrow I guess I bite down and do the FORSCAN thing for full-range. That makes me nervous.
Darelle
New York State
2021 Ford Bromco Big Bend A51
The great-another-hardware-store-run news? The quick connectors are bare wires, so if you want a clean plug then be ready to have those on hand. Unbeknownst to me, I'm somehow out of these, so it's back to Florida-fruit-colored hardware store (non-sponsored).
Nice work @negativezero.im still waiting on mine from Amazon unfortunately. Good to know on the T30 bit. That is weird! Will keep my eyes and hands open for the fragile bits too. When you say bare wire...there isn't a quick connect?
negativezero
Brad
Dallas, TX
Toyota Tundra
Yes, of course - on the side that interfaces with the vehicle system. The other side that goes to the speaker is bare. That's all I'm saying.
negativezero
Brad
Dallas, TX
Toyota Tundra
Everything's in & installed. Confirmed that these fit the 2-door Bronco's and it's all working like it should. More details added to the initial feedback post above ^^^.
