- Mabett
- Dec 29, 2021
- 289
- 2,644
- 4,640
- China
- Website
- www.facebook.com
- Bronco Black Diamond
- Black Diamond
Not fit Base Model!
Posted prototypes on my Facebook group about two months ago, and now they're here, in stock! Buy now!
Stay charged with the Ford Bronco Wireless Phone Charger designed exclusively by Mabett. Featuring a non-slip mat with easy installation and 15W power to charge, the Wireless Phone Charger is perfect for any sized device. Simply place your Qi-enabled smartphone on the center consoleās phone tray for a quick and secure charge without cables.
Buy "Bronco Wireless Phone Charger" directly for $79.99 via this link: https://www.amazon.com/promocode/A1UZ95LLP3Y77G
UPS has delivered to Amazon warehouses, Amazon is transferring these stocks, although people can already search for them on Amazon and can buy them, but they can't be shipped immediately, I think this should be called "pre-sale" , you can click on the links of these products to see the estimated delivery time displayed on the page, I hope it helps you
Very low stock, only 50 sets, I'm still producing, the next batch will take next month to arrive on Amazon
Product Description
What is wireless charging?
Power is transferred wirelessly through a process known as magnetic induction which occurs between a transmitter coil (charging dock) and receiver coil (phone). This magnetic field generated by the transmitter coil induces a voltage in the receiver coil, which is used to charge your phoneās battery.
What phones are compatible with the Bronco Wireless Phone Charger?
iPhone 8 or later, plus Galaxy: Note9, S9, S9+, Note8, S8, S8+, S7, S7 edge, Note5, S6 edge+, S6 edge,S6 and various Qi-certified phones from other manufactures can be used with the Model 3 Wireless Phone Charger. It is best to check your phoneās instructions to verify its wireless (Qi) charging capability.
What is Qi?
Qi is an open standard which ensures the safe and compatible operation of wireless charging devices within its ecosystem.
Is the Bronco wireless Phone Charger is QI Compliant?
Yes. (Compatible but not Qi certified)
Will the Wireless Phone Charger work with phone cases?
Thin, non-metalized cases are supported. Large cases may not support wireless charging.
How is the Wireless Phone Charger installed?
The Wireless Phone Charger be easily installed at home. Please follow the installation instructions below:
What is included with the Wireless Phone Charger?
(1) Charging pad
(1) Non-slip mat
(1) Special adapter plug and wiring harness
How is the Wireless Phone Charger powered?
Charging power supply at the forward part of the center console
What is the power transfer output of the Wireless Phone Charger?
Mabett Wireless Phone Charge provides up to 15-Watts of wireless power transfer.
Product Description
- Support up to 15W Fast Charging
- Ideal for Big-Sized Phones
- Custom Fit&Classic Bronco Factory Look
- Anti-skid mat keep the phone from moving around
What is Qi?
(1) Charging pad
(1) Non-slip mat
