Mabett Introduces Wireless Phone Charger for Ford Bronco!
Mabett
Mabett
Mabett
China
www.amazon.com
Bronco Black Diamond
straycat
Matt
St. Louis, MO
2011 Toyota Camry, 2021 Ford Bronco
Anyone with LUX package install this? Was it better than stock? Initially mine worked great, but now anytime I run over anything larger than pebble I lose connection.
CT203
Connecticut
'13 JK
Apologies but I’m not clear on what you’re saying. Is your factory charger no longer working great, or did you install Mabett’s on a lux and now that is no longer working great?
straycat
Matt
St. Louis, MO
I currently have Lux with the factory wireless charger that doesnt work great. So I'm wondering if the Mabett works better than the factory charger.
CT203
Connecticut
'13 JK
Got it. Same here. The Apple puck install seems a bit daunting, but it’d make a big difference.
Buck₩ild
Buck
Canada
Wrangler Willys, Bronco BD, Cherokee
So the issue is resolved now? What was the cause of the blinking LEDs? Was it just a bad batch? @Mabett
Mabett
Mabett
Mabett
China
www.amazon.com
Mikey D
Ormond Beach, FL
www.mikedelninno.com
2005 Ford Explorer
Not fit Base Model!
Posted prototypes on my Facebook group about two months ago, and now they're here, in stock! Buy now!
Stay charged with the Ford Bronco Wireless Phone Charger designed exclusively by Mabett. Featuring a non-slip mat with easy installation and 15W power to charge, the Wireless Phone Charger is perfect for any sized device. Simply place your Qi-enabled smartphone on the center console’s phone tray for a quick and secure charge without cables.
Buy "Bronco Wireless Phone Charger" directly for $79.99 via this link: https://www.amazon.com/promocode/A1UZ95LLP3Y77G
UPS has delivered to Amazon warehouses, Amazon is transferring these stocks, although people can already search for them on Amazon and can buy them, but they can't be shipped immediately, I think this should be called "pre-sale" , you can click on the links of these products to see the estimated delivery time displayed on the page, I hope it helps you
Very low stock, only 50 sets, I'm still producing, the next batch will take next month to arrive on Amazon
Product Description
  • Support up to 15W Fast Charging
  • Ideal for Big-Sized Phones
  • Custom Fit&Classic Bronco Factory Look
  • Anti-skid mat keep the phone from moving around
Frequently Asked Questions
What is wireless charging?
Power is transferred wirelessly through a process known as magnetic induction which occurs between a transmitter coil (charging dock) and receiver coil (phone). This magnetic field generated by the transmitter coil induces a voltage in the receiver coil, which is used to charge your phone’s battery.
What phones are compatible with the Bronco Wireless Phone Charger?
iPhone 8 or later, plus Galaxy: Note9, S9, S9+, Note8, S8, S8+, S7, S7 edge, Note5, S6 edge+, S6 edge,S6 and various Qi-certified phones from other manufactures can be used with the Model 3 Wireless Phone Charger. It is best to check your phone’s instructions to verify its wireless (Qi) charging capability.
What is Qi?
Qi is an open standard which ensures the safe and compatible operation of wireless charging devices within its ecosystem.
Is the Bronco wireless Phone Charger is QI Compliant?
Yes. (Compatible but not Qi certified)
Will the Wireless Phone Charger work with phone cases?
Thin, non-metalized cases are supported. Large cases may not support wireless charging.
How is the Wireless Phone Charger installed?
The Wireless Phone Charger be easily installed at home. Please follow the installation instructions below:
What is included with the Wireless Phone Charger?
(1) Charging pad
(1) Non-slip mat
(1) Special adapter plug and wiring harness
How is the Wireless Phone Charger powered?
Charging power supply at the forward part of the center console
What is the power transfer output of the Wireless Phone Charger?
Mabett Wireless Phone Charge provides up to 15-Watts of wireless power transfer.
Can this item be returned if I install and it doesn't work with my OtterBox case?
Mabett
Mabett
Mabett
China
www.amazon.com
I'll get a flashing faulty wireless charging pad in 15 days and I'll find out the cause then, sold 50 sets so far, 4 people have the problem, if there are others with the problem, you can return it
Everyone can trust mabett's after-sales service
Mabett
Mabett
Mabett
China
www.amazon.com
Buck₩ild
Buck
Canada
Oh for sure - no denying your after sale service is top notch.
That's why I keep buying your products :)
Was just curious that's all.
bronco_rat
calif
I wonder how this would work with replacing the terrible stock wireless charger that in the lux package
Just swapped this for the factory one. Easy replacement, it seems to work better and my phone doesn't get hot.
