Mabett Mud Flaps Fits Sasquatch set that accommodates factory rock rails or tube steps
Santos
Santo
Lenoir City, Tn
1977F100:1970 Mustang Fastback
Ordered mine! Than you all for the info!
BBoyM3
Robert
San Antonio, TX
2015 Toyota Corolla LE
Suitable for both non-SAS and SAS, and accommodates factory rock rails and tube steps
So, everything fits
Does it work with both types of rear bumpers (steel (Badlands) and plastic (Wildtrak))?
orion1224
2021 Bronco Wildtrak 4Dr Sasquatch
I was having a similar issue getting them out, you need a small tool you can insert between the screw part and the outer ring to help it catch the threads. I used a tiny screwdriver. See this video, it helps explain it.
This worked great- thank you! Fronts are on and look great.
straycat
St. Louis, MO
2011 Toyota Camry, 2021 Ford Bronco
MY Bronco is NON SaS Geez I think I stirred up a S**T storm by accident. I am on stock Big Bend Height with 8.5 Inch wide 17" wheels with -10 offset. My wheels poke a lot more than the SaS wheels I think the Sas guys an girls should be fine.
Which tires do you have? I have same specs as you (35s, 8.5", -10 offset, Non-SAS), but the pic you showed seemed to indicate they're a bit more "aggressive" than mine. I have already received my flaps, but haven't tried to install them yet. Wonder if I should just return them and save the hassle.
Romano
Roman
Portland, Or
Bmw/Honda/Ford
Wait. What?
Are the "fits Sasquatch" mud flaps incompatible with 35" tires?
How can that be when every Sasquatch comes with 35" tires?
Mine arrive Saturday... and I have a Sasquatch. More info, please?
If you have a non Sasquatch with 35”
orion1224
Fronts are on and look great! Will be driving off road next week in blue ridge mountains area. Hoping this does the trick! My specs-
Sasquatch
35s
The step bars are nfab.
Ford Bronco Mabett Mud Flaps Fits Sasquatch set that accommodates factory rock rails or tube steps 7EA16D0B-2C29-4671-8D6D-E45DE7CC79E2
Ford Bronco Mabett Mud Flaps Fits Sasquatch set that accommodates factory rock rails or tube steps 99A76E2B-6848-42AF-9379-610043204D81
Romano
Roman
Portland, Or
Bmw/Honda/Ford
How long before you have non crashbar mudflaps ready for the Sasquatches Mabett? Thank you for such great products!
MudMonsterRacin
PA
2003 Mach 1, 2016 F150
They look like they fit great. I wish that u had a set for the non sasquatch broncos that doesnt stick out past the fender flair kinda like they fit on the sasqatch.
Cfield90
South FL
21 Bronco/22 Escape/01 Softail/90 Bronco (former)
Didn’t watch the video, but was going to recommend to aggressively pop them off. If one breaks, you have a spare—assuming you didn’t mash up the others.
For others having issues, a trim pry tool worked really well. I tried to unscrew, but as noted, they just spin. I was having some issue trying to get them back in as a solid unit, but when I removed the screw, it worked. Kinda a PITA but hold the the base piece tight (like a tiger) while screwing in.
Keerplunk
Izzy
Burbank CA
2007 Jeep JKU, 2022 Cyber Orange 4Dr Bronco
I have the Good year Duratracs
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
I thinks its more of the offset vs the tires. I have 35" BFG KO2's which are nearly the same size as the stock SAS Goodyear tires 34.4-vs-34.5. SAS stock offset is +30. I have Method wheels with a 0 or neutral offset and had major rubbing.
straycat
St. Louis, MO
Yeah, was afraid of that. Thanks. Looks like I'll just return these before even trying to install them and wait for an updated version that will handle the -10 offset I have.
feeble
Shawn
Yankton, SD
2022 Badlands, 1977 Cobra II Monroe Handler
I’d also like to know. Anyone tried these on the rear of a steel bumper Badlands yet?
Aurongel
M.
Austin, TX
2016 Dodge Challenger RT
I cannot for the life of me get the expansion screws to “stick” in place and hold the flap to the liner. Right now it hangs out over the crash bar 😔
