- Alex
- Oct 23, 2020
- 30
- 2,931
- 5,641
- Cleveland OH
- 2022 Badlands
- Badlands
You need to run the large wiring harness to each head light and then back in to the vehicle harness. You need to connect the trailsight light to one of the thin white connectors on the large harness and then you use the add a fuse harness and run it between the two and up to the battery. Your missing a crucial step it sounds like based on your answer to me in the other thread above and that would explain why you have no power. If I understand you correctly, currently your trailsights are not connected to your headlights. That would explain your issue.Yes I’m only trying to run from add a fuse. The instructions state that as an option for being on all the time.
I installed the lights fine today and am having no luck powering them with only the fused connection. I ran the wiring like the instructions said and plugged them into spot 124 in the fuse box and nothing lights up with engine start. I’m not sure but shouldn’t the fused connection have a ground when not using the headlight module ? So another thought is it possible to direct wire them to one of my aux switches ? Thoughts ?
Thanks I’ll check that as well. So the question is has anyone wired them with add a fuse only and not through the headlight module ? If so what did you do.
