Mabett Trail Sight LED Lights for Ford Bronco 2021-2023 Available Now!
jbacchi70
Joe
Jeep GC, 1968 Plymouth Road Runner
Could you shoot a video for me to check ?
Thanks for responding! I think it's ok; it just took a really long time for the lights to shut off. All good.
tractorcrusher
Curtis
DFW, TX
Two questions, as I've been considering buying these for about a month now-
Are the dimensions the same inside the mounting area of the trail sights? I have limb risers that I put on when I go through the woods and the mounts need to fit the same as the OEM trail sights.
Second, and I'm not trying to cause drama- but there are several reviews on amazon saying some of the LED lights are failing already inside the trail sights. Are those just one-off defects or will there be a manufacturing change to address this? I feel like even if these are replaced under warranty it will be a pain to change them out.
Mabett
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
The size is same. We will do test to fix it.
Jayalamo
Jay
Chicago
2023 Ford Bronco Big Bend 2 Door
The best solution to make your Ford Bronco stand out! The Kit allows you to change your factory Trail Sight assemblies to Aluminum Alloy Trail Sight LED Lights in your Bronco OEM Trail Sight locations, and this kit gives you everything you need to mount the lights for a clean, from-the-factory look.
Made from high quality components, these complete assemblies are plug-and-play and completely reversible with no cutting or splicing
Buy through the promotional link provided by Mabett and enjoy a 38% discount!
Promotion link: https://www.amazon.com/promocode/A3P8KI7LTYSJ6V
Product Description:
  • COMPATIBLE with full-sized Ford Broncos!
  • From-the-factory look
  • PLUG and PLAY no splicing or wiring required!
  • DRL, Sequential Turn Signals
Light parameters:
  • Watts: 3.5W
  • Current: 0.26A
  • Color Temp: 1.8K~2K
  • Lumen: 270lm
UPS has delivered to Amazon warehouses, Amazon is transferring these stocks, although people can already search for them on Amazon and can buy them, but they can't be shipped immediately, I think this should be called "pre-sale" , you can click on the links of these products to see the estimated delivery time displayed on the page, I hope it helps you
Only a few dozen sets are currently in stock, if you missed it please let me know you need it! This will give me the confidence to produce more stock!
If you've already purchased don't worry I can refund the difference please PM me, but I get a lot of messages every day, so the reply will be slow, even days
Updated on May 4th, U.S. time.
I would like to draw everyone's attention to the Trail Sight Lights. Please take note of this important matter.
Hi everyone, please take note of the issue that Paul Short has discovered
Paul: I discovered a small issue with the short harnesses in the kit. Please view the attached photo. This should save a little frustration.
I will make sure to pay close attention to this issue during future quality inspections.
I would like to apologize to everyone for any inconvenience or issues that may have been caused.
I was looking at Mabett fog lights for the steel modular bumper and wanted to know if anything was coming out that would connect to the 2 small extra plugs that are on the wire harness. Instead of using the fog lamp button I wouldn’t mind the same functionality of the trail sight but with the fog lamps. I.e turning light and drl etc.
Jayalamo
Jay
Chicago
Anyone know if 2 of the headlight wire harness will work in tandem? I’ve seen some fog lights that hook into head light with similar wire harness as these and figured I could connect them together so trail sight and fog light have the same functionality
Mabett
Mabett
Mabett
China
www.facebook.com
They can work in tandem.
CUPRA
Jared
'21 Bronco OBXSAS/'23 Camaro SS Convertible
Yes they do, in my latest install video I do just that with a set of Mabett LED fog lights AND their Trail Sight Lights as well.
Jayalamo
Jay
Chicago
Awesome, exactly what I was looking for. Too bad it didn’t come with a fuse cable to be on all the time like the trail sights but definitely useful. Thank you.
Jayalamo
Jay
Chicago
Curious would the harness for this fog light be compatible with these fog lights? I like the steel housing better
CUPRA
Jared
The connectors do appear to be the same or similar for sure. But I haven’t tried it to find out.
Let me dig out the other set of lights and see if the harnesses fit with each other.
Jayalamo
Jay
Chicago
Thank you for checking
CUPRA
Jared
Ok, so I just checked them out.
Unfortunately, you can’t use the harness from one with the other. The 5 LED fog lights that has the headlight harness has a female connector on it. The male is on the fog light.
The 4 LED fog lights with the steel housing, the lights have a female connector on them and the harness has a male connector on that end. Meaning you are trying to connect male to male.
So you’d still have to adapt the harness, cut off a female connector and replace the male connector.
Hope this helps tho.
Ford Bronco Mabett Trail Sight LED Lights for Ford Bronco 2021-2023 Available Now! IMG_4477
Ford Bronco Mabett Trail Sight LED Lights for Ford Bronco 2021-2023 Available Now! IMG_4479
CFALevelFore
Joe
Littleton, CO
I recently installed the Mabett LED trail sights and was wondering if I can wire the extra harness that goes to the fuse box to an (aftermarket) auxiliary switch instead? I don't think this would be the case, but I don't want to risk sending voltage the wrong way through the harness that connects directly to the headlights. @Mabett
Great White North
Trace
Victoria BC
2013 Ford Edge SEL, 1975 F-150 Ranger XLT
Is it possible to purchase just the harness adapters? I have a set of Strands Qube lights that have white and amber running lights that I would love to connect to the daytime and indictators without butchering the existing wiring to add the feature.
