TheGhost
Central TX
2021 Bronco Badlands, 2009 Mazda RX-8
I don't know a lot about exhaust upgrades so sorry if this is a stupid question... but are there any performance or MPG improvements or is this truly just for sound?
I'm sure MagnaFlow (and other vendors) will post dyno charts showing an increase in hp, blah, blah...for most modern turbocharged vehicles, there is minimal performance gain from a catback. It is typically the downpipe and cat where the cheaper bends of OEM exhaust piping seriously holds back performance of the turbos. Everything downstream of the cat is mostly for sound. But at least in this case, it can be for sound and better clearance when off roading.
AMK610
Andy
PA
2019 RAM 1500 Rebel
dunno much about exhaust but this is what he said in the comments
"SPD Performance Catless downpipes with MBRP 4” exhaust and a BOOMBAracing BOV"
A cat less down pipe is going to turn the volume up by a lot. It’s also gunna be pretty stanky
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
You should do a Sound video with "all 4" tones separate, so buyers can decide if one of those tones will work for them. Not too hard if it's just taking the turned pipe after the muffler on and off, and adding the Drone diffuser or the cap. Then, when they buy it, they will know which one to use ahead of time. Saving the customer time is golden !!!!
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
Do you even need to run a muffler on a turbo engine? Can you get away with just a resonator to remove the drone if there is one?
JBOZ
Tracy,California
2019 F250
I like it.
nminus1
Henry
High Desert So Cal
Chevy Duramax, Trailblazer, and Ford Escape
The aftermarket mufflers I had on my Camaro were perfect for drone elimination, they had a butterfly valve in them with a spring they would only open and bypass the main muffler under 2/3 to full throttle I loved them. Wish they had those for the V-6 Bronco I'm getting, anyone know if they still make them? Can't find them.
taguirre
Tony
Seattle
2021 Outer Banks Bronco
The sound of the 2.7L is actually very good. I don't know how they did it but it sounds like an old 302 at times. No need to mod this IMHO
omega145
Rubicon Recon
I think it sounds good. Wonder what it'll sound like without the rear muffler. Have hacked a few off turbo 6 cylinders and they usually sound pretty damn good.
flynh3
McCook, NE
Put one on last week...changed the resonators around and checked the sounds...so after some thought, going to cut the U pipe at a 45 angle...it exits nicely off to the side. Toss the resonator. Now instead of sounding like a souped up Singer sewing machine, it might sound a little throatier...sure don't want it to sound like a Subaru. Take a look at my scribbles and notes on the install sheet...
I'm not sure this item is worthy of an install...if you are looking for a V-8 sound...remember it's 2.7 with a 10 speed tranny...I'll keep you posted on progress.
BRONC0
Austin, TX
2013 F150 FX2
Ford Bronco Magnaflow Overland Exhaust for 2.7L Bronco - look & sounds exhaust2
@flynh3 I'm curious if you ended up doing the cut to the U pipe and the results?
flynh3
McCook, NE
