Mansquatch through DIO?
BadlandsBroncoBen
Ben
Denver CO
2019 Subaru Outback, 2015 Subaru BRZ
Hey all, I was wondering if anybody ordering a Badlands with the 2.3 and Manual transmission has talked to their dealer about having them add the suspension bump stops and fender flares from the Sasquatch package and some 35"s at the dealer. I want to row my own gears AND have big tires AND not have to wait till MY22, and doing it through the dealer seems like a potentially good workaround. What do y'all think?
Rydfree
Benny
Alabama
You're probably still going to be waiting awhile until the dealer can get those extra parts .
Demoncleaner
SE Wisconsin
2021 Jeep Gladiator Mojave 6 speed
Where did you see something that stated 2022 MY for mansquatch?
BeerForMyHorses
Jared
Idaho
Ford Bronco 2-Door
I'm assuming budgeting is not an issue then? Because upgrading the Badlands to Sasquatch is $2500 from the factory, but will probably cost more having a dealer piecemeal that together
hemiblas
Roger
Aurora, Co
17 mustang gt, 3 Wrangler JLs
I doubt the dealer will have all those parts on hand if you have an earlier reservation. Best solution is to just drive it off the lot like that and then add them yourself as they become available.
Baltimore, MD
As others have said, the squatch parts won’t be readily available for quite some time.
You’d probably be better off hitting up the aftermarket for a lift unless you don’t mind waiting a year or so for OEM parts.
Demoncleaner
SE Wisconsin
not just mansquatch, even late reservations may be a 2022 Bronco
Ford Bronco Mansquatch through DIO? 9F372048-28ED-4B61-848A-8D8E05B88B32
I’m a second day reservation, but I really want a mansquatch. I guess I’ll see what happens when it’s time to order. If Ford says manual trans+Sasquatch will be a 2022 option, not sure what I’ll do. I’d like to keep my spot so to speak.
andi
Why can’t u just get the Sasquatch then lol, why make it hard on urslef
BadlandsBroncoBen
BadlandsBroncoBen
Ben
Denver CO
Because I want a manual transmission
andi
Aman
Aman
Northern NJ
I think it would be a much easier decision if Ford would state what the actual differences are between the Badlands suspension and the Sasquatch suspension.
I am generally patient, but I'm not sure I want to wait for a Mansquatch. Thinking about getting the 33's with the optional bead-locks or having @Granger Ford install a set of true 35's and necessary parts before delivery.
ffdemoss
Northwest Arkansas
2009 F250, 2017 Fusion, 2014 Escape, 2005 LJ, 1968 M715
The aftermarket is going to be way cheaper and probably blow away anything a dealer will cobble together. Buy your MT Badlands and save up for all the aftermarket can throw at you.
