Maybe they will approve a complete transmission like many others have gotten?Agreed. Only problem is there’s a massive back order on the transmission case with no ETA at all.
Hopefully. That’s what I would be doing in their case to help the customer out and make things right.Maybe they will approve a complete transmission like many others have gotten?
And this is what the first lady mentioned. Thats why they were going to have it welded. Id rather wait a year then have that done.Agreed. Only problem is there’s a massive back order on the transmission case with no ETA at all.
I would want them to weld it to get you back on the road, but order the part whether it's the case or whole new unit to replace whenever it comes in.And this is what the first lady mentioned. Thats why they were going to have it welded. Id rather wait a year then have that done.
Nice! Glad they are doing the right thing for you.Update... They are replacing it with a new transmission.
Well Boys, Second times the charm? I’m not holding my breath, but the BL is in for attempt #2 at the TSB.
I purposefully left it with ¼ tank of fuel so the techs have less chance of fuckin up the fuel lines due to extra fuel weight.
This time around they only have the correct synchros, not version 1 and 2, as we reordered when the revision came out - and I don’t think they trashed the original set.
Either way, I’ll report back as she goes.
Hopefully I don’t piss off Dukaki/Donkey/Ducati too much![]()
Good luck! Hope you get a quiet set this timeWell Boys, Second times the charm? I’m not holding my breath, but the BL is in for attempt #2 at the TSB.
Escalate with customer service or try another dealer.Have had TSB which failed and noise returned.
Have had the AB transmission replacement, noise returned.
Now dealer says that's how it's supposed to sound and refuses to touch the transmission again.
I'm being forced to drive a lemon and deal with it. In addition to the noise. 2nd has a frequent crunchy rough feel in stick when engaging. What now?
You’re not being forced to do anything.Have had TSB which failed and noise returned.
Most of us waited for over two years to get our Broncos, and have been going through many headaches with these transmissions since then. Thus selling is not something that many of us will consider a satisfactory outcome. We should all try to pressure Ford Motors through their headquarters, attorneys, and whatever it takes to fix this problem.Have had TSB which failed and noise returned.
