Max Lightbar width?
FieryBronco
john
Rochester, NY
Any ideas on a theoretical max lightbar width? I have some lightbars leftover from my ‘13 f150
wigid
Richard
Nashville TN
Nissan Patrol
most of the ones we have seen are 40 inch lightbars.
FieryBronco
john
Rochester, NY
I have one of those so I should be all set there. I also have a 52" that I was hoping to re-use
604Bronco
British Columbia
www.bronco6g.com
Just curious where this info can be found for a 40" light bar on the Bronco? Reason I ask is I currently have a 30" light bar and just want to be completely sure it won't work before I sell it off.
Thanks!
Low Hammer
Idaho
10th gen F150
Should be easy to figure out a decent guess about the length of that roofline from doing some geometry. From a Roadshow Video. 65"/(19 squares) is ~3.42 inches per square. 17 squares so roofline is ~58 inches across.
Ford Bronco Max Lightbar width? 1618201047015
Also worth mentioning that the build and price included lightbar is 40 inches and seems to fit between the rack mounts so that would be 12.5 squares across on this so ~43 inches across by that logic.
Since you're hoping for a larger roofline it makes more sense to assume conservatively. So I'd just say assume the roofline is at least 55" across.
604Bronco
British Columbia
www.bronco6g.com
Thank you! This is very helpful info.
That 73.9" high - Do you know if this is with the 35" tires and Sasquatch package?
Low Hammer
Idaho
10th gen F150
I don’t remember offhand, but this is where I got it from
okbob
North of the Red
71' u15, 66' u14, 66' u14
Light bars are for Jeeps.......
604Bronco
British Columbia
www.bronco6g.com
Nahh man they don’t get the monopoly on night wheeling
Agreed. All off-road vehicles should have the option.
I'm really curious to see how good the LED headlights are on the Bronco. I realize they'll be nothing like a light bar, however I've seen some very good and some very bad lights before...
