- Ronnie
- Oct 30, 2021
- 14
- 40
- 84
- Powhatan VA
- 79 f250, 71 Super beetle, 05 F150, 22 bronco sas
- Base
So... My dealer couldn't get me in for my first oil change... I said ehh, big deal, went to Walmart got 7qts motorcraft 5w30 and the filter..
Everything went well, broke loose the filter first and pulled it... That's when I saw it, metal shards on the filter.
What looks tho have happened is the metal threads that are cut into the front cover/intake for the filter housing were never cleaned after machining. I used a microfiber and kept wiping the threads and getting more off the threads.
After the oil change and cleaning I did a throttle and brake pedal down prime to start, oil light went out and I started it and it sounds fine and no oil lights.
I've put about 600 miles on it since and it seems fine, I changed the oil at 5000 miles because I'm NOT waiting for 10k. My neighbor was there and freaked out, said I should take it to the dealer, I don't see why because there's literally nothing they can do at this point. (I worked for Ford service for about a year).
Just figured I'd warn everyone, if I had taken it to the dealer I never would have seen this... I didn't use any sprays or cleaners, just a microfiber and all seems ok now.
