Doetsch Off-Road
Todd
Chandler, AZ
www.doetschoffroad.com
2021 Badlands 4dr, 2021 Wildtrak, 2021 Rubicon 392
We like to combine upgrades between things you see and things you don't. In the case of Mike's new 2022 Ford Bronco, we're plugged in with top manufactures like Fabtech Motorsports which allows us to get products ahead of the general public or as they're about to drop.
We've installed quite a few of Fabtech's Dirt Logic 2.5 Resi Coilover kits which also feature front upper tubular a-arms and rear lower adjustable arms, to correct suspension geometry, but now also their new tie rod Heim kit. This new Bronco upgrade features 3/4" FK Heim ends, thicker than stock billet aluminum adjusting sleeves and heat treated stainless steel clevises and tapered pins. This formula is a great solution for the weak factory tie rod ends which we've seen break with moderate to heavy off-road use.
Next, we fit a set of 37x12.50 Cooper STT Pro tires with 17" Gunmetal Fuel Off-Road wheels, including a matching spare which is getting a future upgrade to a new style tire carrier and reinforcement bracket (stay tuned!). Last but not least, a pair of electric slider steps from Rock Slide Engineering. Fabtech 2.5 Resi Coilover Kit - https://doetschoffroad.com/products...the-2021-ford-bronco-bilstein-factory-shocks1
and https://doetschoffroad.com/products...logic-resi-coilovers-for-the-2021-ford-bronco Fabtech Tie Rod Kit - https://doetschoffroad.com/products/fabtech-tie-rod-heim-kit-fts22349
Rock Slide Engineering Steps - https://doetschoffroad.com/products/rock-slide-engineering-gen-3-step-slider-set-ford-bronco-4dr
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279488871_2332329983576654_3407065566390980795_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279516379_2332324830243836_9117219366578778010_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279525316_2332334653576187_1214116187364717659_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279377907_2332334606909525_4269598751508306116_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279486567_2332329970243322_6979950181729617317_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279494568_2332324853577167_4406766205348259196_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279497836_2332324843577168_7699143582065648037_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279520497_2332320350244284_491055851092487080_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279551960_2332320400244279_7135291684214081805_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279260989_2332320386910947_5782870048067021205_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279527610_2332320420244277_598184436993086745_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279260989_2332320320244287_3650099395614852385_n
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 279520923_2332339556909030_1435032472478479843_n
SZairborne
Shayne
Minnesota
2018 Dodge charger GT AWD
Looks amazing!
MAK3
Chandler, AZ
2017 Ford F-250 Lariat
Thanks so much to Todd and the whole team at Doetsch Off Road - canā€™t say enough positive things about these guys and the experience Iā€™ve had with them with both of my broncos! Super knowledgeable and quality workmanship - worth every penny! Iā€™m lucky to live in Chandler, AZ and have these guys in my backyard. AND these pictures while great donā€™t do it justice - itā€™s TALL and beefy! Here is a pic of my wife standing next to it on the step for perspective and sitting next to a lifted Rubicon with the same tires.
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 4CEEED03-42CF-4BB0-B604-FBBC6F97D831
Ford Bronco Mikes Carbonized Fabtech & Fuel Badlands build on 37s 4E754AB2-C0E5-4999-82E1-B34DF94E53A6
AIGAD
Tom
UT
2021 Badlands Sas
That looks awesome! šŸ‘Œ
I'm glad to finally see the D752's on Carbonized Gray. I've been eye-balling those for awhile.
Yetibronco21
Luis
Astra#2020
Hey man whatā€™s the offset on the Blocks, I have the same wheels and getting installed on Monday are a set of 37x13.5 MTZā€™s
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
Badass!
Doetsch Off-Road
Doetsch Off-Road
Todd
Chandler, AZ
they are a 0 offset. 13.5 tires are generally too wide for most broncos. Youā€™re going to need to cut off some of your crash bar mounts
HeHateMe
San Antonio, TX
2020 Hyundai Palisade
Interesting the Rubicon tires look bigger... Or rather, wider.
Why are Bronco tires so thin?
Doetsch Off-Road
Doetsch Off-Road
Todd
Chandler, AZ
The Jeep had 13.50 the bronco has 12.50s which is a better fitment for it at least at this particular configuration
Hellion10
Jerry
Denair Ca.
'19 Audi A7 Prestige, '23 Tundra Capstone, ā€˜69 C10
NICE AND CLEAN!!!!! Badass build. I know you didn't build it for the Highway, but out of curiosity what kinda mileage you getting with he 37's and other mods?
MAK3
Chandler, AZ
Itā€™s gonna be my daily for work as well and rides fantastic on the road. Only has 400 miles total on it šŸ˜‚ so a little early to tell and the Speedo isnā€™t recalibrated (yet) but showing 13 miles per gallon right now and climbing. My F250 on 37ā€™s has consistently gotten about 13.5 miles per gallon (diesel) the past 4 years so really doesnā€™t matter which one I drive except that gas is cheaper! Iā€™ll come back to this after I get some more miles and keep you posted.
Hellion10
Jerry
Denair Ca.
Thanks for the info, big fan of your ride!!!
