Milwaukee M18 Air Compressor Sale
Desert_Brush
SoCal
2015 Mini Cooper
For those looking for a good cordless air compressor for air ups, this is probably the best out there now, can do each tire from 10-35 in about 2 minutes.
Milwaukee M18 cordless, comes with 2 batteries, and a charger, for $199 @ Home Depot with free delivery if you need.
I don't expect this to get any cheaper, especially for a cordless.
I have this as my secondary compressor for when I off road. Works perfectly fine and super easy to move from tire to tire and quick too. I do find it runs 2psi below Bought it with this exact same deal a year ago. I have the Viair as my primary, but always have a backup. Also super useful if you have more than one car too.
OverlandingPastor
Louisiana
2012 Wrangler
Batteries and charger delivered today but not compressor yet. Home Depot support said its not unusual for these kits to come in multiple shipments. Anyone else have that experience with this deal?
Update 12/1/23: Compressor came in 2 days later and everything works great!
Dmorty217
Derek
Venice FL
Camery
mikeeshim
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
Not sure why you guys didn’t buy the Trickflate. Thing is a beast and $80 cheaper. Don’t get me wrong I’m a Milwaukee guy, but this is better
https://td-distributing.myshopify.com/products/trickflate-dual-cylinder-12v-300-l-min-air-compressor
I have one almost just like that from Summit, but getting to the hood every time was a hassle (I got stuff on the hood that I need to undo before opening it).
Also, the Milwaukee is cordless and really quiet compared to these types, and much easier to switch between cars when you have more than 1 vehicle. My Benz has a battery in the trunk under the spare tire lid and it was a pain as well with all of the stuff in the trunk.
Both have their pros and cons, I got this for the convenience factor. Also have an excuse to buy more Milwaukee tools now and slowly move away from Makita. :ROFLMAO:
mikeeshim
mikeeshim
Los Angeles, CA
Mine shipped and arrived together, but in separate boxes. Hope one of yours didn't get lost.
BigFootie
Wisconsin
Mine came all together in one box consisting of two other boxes.
Dmorty217
Derek
Venice FL
Camery
I’ve got 30 Milwaukee m18 tools/ corded tools and love them.
AZMikeL
AZ
This:
This compressor is not designed for 1 tire at a time and should be used with a 4 tire hose system. You can still air up a single flat if you need to, but the duty cycle dwindles to 2min doing 1 tire at a time. Airing up an entire vehicle, 1 tire at a time, will damage the Trickflate.
So, a 4 hose system, even a BYO, would probably make the cost about the same if not more. Also, not wanting to wrestle with an Octopus (err... Quadropus?) just to air up. We're often short on room for most trips.
Not needing to pop the hood and deal with running from the battery to rear passenger tire is a huge plus as well. This thing is a huge step up from my 17 YO compressor. That thing takes around 8 mins to air up from 18 to 35 on my stock 35 GYs. I've seen reports of guys airing up 37s from/to those same pressure in just over 3 mins.
thewodg
Matt
Massachusetts
A4
This deal still appears to be available elsewhere online.
Before I pull the trigger, I'm wondering if a High Output (HO) battery would increase the speed/output of the inflator? I'm a bit worried about how long it will take to air up the squatch 35s from 11-39 psi.
BigFootie
Wisconsin
The bigger battery won’t increase the speed. It’s still 18v. You just can go longer before charging.
thewodg
Matt
Massachusetts
A4
Yeah, I suspected the battery size wouldn't make a difference but thought the "high output" designation might.
BigFootie
Wisconsin
Can't say for sure with the compressor, but it is pretty obvious with the impacts when you have a big or small battery in.
It could be tool dependent. I haven’t noticed a difference on most of my outdoor tools other than extended time. I have sizes from 12 to 5 for the 18v tools. I generally use the 6.0’s on the impact. The 12.0 is physically big and some tools won’t sit correctly with it in. The compressor might be one of those. I know the fan doesn’t sit flat with the 12.0 but lasts a long time! I can take a look to see if I can hook up a flow gauge to the compressor to check.
thewodg
Matt
Massachusetts
A4
Thank you both for the insight!
@BigFootie, I'd definitely be interested in the results of that test.
I'm also seeing reports online of people having issues with the HO batteries when used with the inflator. Perhaps the simple XC is the way to go. Certainly cheaper!
BigFootie
Wisconsin
I just checked with a coworker whose son is an engineering manager at Milwaukee. He says it will only affect the output with regards to run time meaning the output or flow rate will stay higher longer with a 12.0 vs. a 5.0.
