Minimal recovery kit contents?
Myke98
San Diego, CA
21 Wildtrak
Knowing that I will always be out with a group, what would be the necessary items to have in my recovery kit knowing that I will have most everything available with our group that goes out every other weekend? I may go with them a 5 or 6 times a year. This will be in SoCal so I don't need anything mud related.
Also what is a good economical bag to carry?
So far I have:
3 D-rings
Receiver d-ring adapter
Air hose and fill gauge for my onboard compressor
Air down gauge
Spare tie-rod end
goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
So far I have:
3 D-rings
Air down gauge
Spare tie-rod end
You have rear tow points, don't you? Then you wouldn't need the receiver adapter. A D ring for the front is all you'd likely need. We've all gone to soft shackles, more versatile and much safer than the metal D rings. A tow strap and a short tree saver strap so you have your own. Any tool bag from Harbor Freight or Home Depot will work fine to put the stuff in. I'd include a tire plug kit. I know you have a spare, and your friends likely carry plug kits, but you never know when you might be out by yourself and a plug kit is cheap insurance.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
So far I have:
3 D-rings
Air down gauge
Spare tie-rod end
Recovery boards and a strap.
WheelMe
Patrick
Northern California
2022 Bronco Badlands Sasquatch 2.7L
I don't like to depend on others on the trail, so other than the above mentioned, I bring a small set of hand tools: ratchets, sockets, wrenches, screwdrivers, pliers, steel-wire, rubber/steel mallet, breaker bar, duct/electrical tape, etc.
Also, can you change your own tires? If you're lifted, you'll need a Hi-Lift, which fits neatly on the trunk floor (diagonally) of a 4D.
Lastly, be sure to have a proper first-aid kit.
Sewie
Sean
San Jose, CA
74 Bronco, 22 Bronco BL Sas 4D
Seeing posts about people bending the rear crossmember when towing/backing into things, I would be hesitant to use a receiver adapter for recovery on the Bronco. If you're worried about pulling dead center you can make a bridle with a tree strap between the rear recovery loops.
Others have listed the basics:
Kinetic strap/rope (not a cheap tow strap with metal hooks)
Tree saver strap
Soft shackles preferably, if you have 3/4" D-rings, they'll work, just check their rating
shovel if you'll go in sand (likely in SoCal)
Basic tools to change things like tie-rods, remove bash plates, etc.
Good pair of gloves!
HoosierDaddy
Indiana
^^^^ golden suggestions right there.
I have a pair or two of decent leather gloves, primarily for if I have to handle a wire winch cable.
Other than that, the usual stuff.
a pretty decent tool/socket/wrench kit.
tow strap
tree strap
d-ring/shackles/clevis
Myke98
Myke98
San Diego, CA
21 Wildtrak
Great suggestions and stuff I did not think of. Thanks for the replies!
Felix808
SRV CA
From what I have seen of the tow hitch frame bending issues, I think the tow points would be stronger as well, as they are linear instead of a cross plane load.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Good suggestions. (y)
What lift points do you use on the Bronco with a Hi-Lift?
Sewie
Sean
San Jose, CA
There aren't any that I'm aware of. Probably need the bumper lift and/or lift-mate attachments. Or some other way to hook to the wheel, under bumper, or to recovery points.
WheelMe
Patrick
Northern California
My past rigs had sliders (my jacking points) that bolted to the frame - not the case with the Bronco... but if the Bronco sliders are strong enough to ward off rocks (and they are), I wonder if they merit a "test"... anyway, topic for another thread.
Sewie
Sean
San Jose, CA
I don't think its the mounting that is the problem with the factory sliders, I think it is the angle. There just isn't enough to grab. My other trucks have had tubular sliders which would fit in the cradle of the hi-lift.
I have factory sliders and a hi-lift, so I guess I could test. Maybe take the doors off first. :oops:
SuperDave150
Albuquerque, NM
Ford F-150, Ford Edge
Tree saver strap
I was going to add shovel. You beat me to it. 👍
(Folding army style)
Also consider what you would need to comfortably survive 24 hours in the backcountry.
goatman2
Richard
Bakersfield
gandgautorepair.com
Most of us haven't carried a high lift jack in a long time. A hydraulic jack or taller scissor jack under the axle will handle any tire change. A high lift comes in handy for more serious trail repairs. The last two times I was involved in using a high lift on the trail were to repair a broken rear leaf spring on an XJ, the Bronco doesn't have leaf springs. The other time was on a rock buggy that broke off an upper control arm bridge and the axle rotated. That one actually took two high lifts and three winch cables to stabilize the buggy. But, if two control arms break off of a Bronco, a welder would be needed as well as high lift jacks and winches.
Not saying don't carry a high lift, but kind of pointless to carry one for the purpose of changing a tire.
