Mishimoto's Performance Stock Location Intercooler R&D Thread
Mishimoto
New Castle, Delaware
F-250
Hey Gang!
Nick here, back again to kick off another thread to show the work we've been doing on some more Brocno goodies! This time we have something more for the folks who are planning for more power rather than the over-landing equipment, and we're diving into a performance stock location intercooler! We have a TON more info over in the latest post on the Engineering Blog:
Low Road – 2021+ Ford Bronco 2.3L/2.7L Performance Stock Location Intercooler R&D, Part 1 – Stock Review and Design Plans
When it comes to the Bronco specifically, there are a few aspects about the intercooler’s design that lock away power potential in both of these EcoBoost engines. First, Ford opted to use the same intercooler between the 2.3L single-turbo four-cylinder and the 2.7L twin-turbo six-cylinder for starters. It’s not uncommon for manufacturers to reuse components across their fleet to cut costs, but that comes with some compromises since a properly sized intercooler is vital for best performance. Oversizing the intercooler core can lead to increased turbo lag and slower response from the vehicle. Whereas an undersized core, especially when it’s cooling for two turbos, will soak with heat much quicker, returning high intake air temperatures and diminished performance. For the most part, this intercooler provides adequate cooling suitable for both engines during daily commuting duties but will quickly fall behind once more is demanded from the system.
Since we’re retaining the same mounting location for this intercooler, we have performance first on our mind, and performance starts in the core. So, to beef up the cooling power for both Broncos, we plan to bulk up the core’s thickness for an increased core volume and improved cooling power. Increasing the size of this intercooler might seem counterintuitive to an intercooler shared between two different engines. Still, the larger core volume is best for use with higher boost pressures resulting from tunes or bigger turbos, so this design is the ideal choice for those looking to squeeze more power from either EcoBoost...read more...
For those planning for a more off-road oriented build, don't forget that we're also working on a high-mounted intercooler to clear some space for winches and other recovery goodies. Make sure to check that out over here - High-Mount Intercooler
We'll have plenty more coming for both of these projects, so make sure to stay tuned, and don't hesitate to reach out with any questions! In the meantime - are you planning for a more on or off road dedicated build for your Bronco?
-Nick
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
So excited for this, think itll by here by summer?
Mishimoto
Mishimoto
F-250
We're working on expediting this intercooler so that we can get them out to you guys ASAP! Nothing's set in stone yet on a release date since we're still working through the design phase, but I'll keep you guys posted as we get closer!
-Nick
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
-Nick
ty!
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Definitely waiting patiently
Raskew
Rick
Vancouver, BC
1970 Bronco, 2018 Stinger
Is it possible to move the inter cooler anywhere, so that you could fit a hidden winch behind the bumper?
Mishimoto
Mishimoto
F-250
Hey Guys!
I just wanted to bump this thread with the latest info on our stock location performance intercooler! As always, make sure that you head over to our Engineering Blog for the full scoop!
LOW ROAD – 2021+ FORD BRONCO 2.3L/2.7L PERFORMANCE STOCK LOCATION INTERCOOLER R&D, PART 2 – PROTOTYPING
t’s no secret that the Bronco wasn’t resurrected to break land speed records. Just one look at this brick on towing off-roading tires makes it apparent that this machine was destined for more wild pathways. No matter where these Broncos feel at home, more power is still a necessity both on the trail and for the commute to work. Luckily, Ford stuffed different iterations of their platform that’s become synonymous with power potential – the EcoBoost. Whether it’s the 2.3L or the 2.7L, these engines have plenty of surplus performance locked away that can be accessed with the correct key. In this case, that key is intercooler shaped. Read More...
As always, don't hesitate to reach out with any questions that you might have!
-Nick
Mishimoto
Mishimoto
F-250
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Cant wait for them to be released
2ata
Bob
Curr.: 2021 Ford Bronco; '77 924, '01 986, '02 911
Patiently waiting…….well, sort of patiently…..
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Lookie what we got today:
Ford Bronco Mishimoto's Performance Stock Location Intercooler R&D Thread NT6_3360
More to come soon!
-Nick
By the time it’s available, I should be able to outright buy it
any group buys planned?
2ata
Bob
@Mishimoto
I’d be happy to install one right now. You know…….to help test….;)
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Whats it gonna cost, intercooler and charge pipes and eta on when its available, plus group buy?
