Modular bumper Question fog light question
Bronc N Roll
Joe
Newport Arkansas
2023 Bronco
I have a base 2 door 2.7, that came with the modular bumper. Anyone know if it is pre wired to add fog lights? Was hoping it was a plug and play option. I appreciate any advice
HBTFD
Newnan GA
F350
It is not pre wired. If you have the optional up-fitter switches itā€™s easy to wire from the brake booster area to the bumper.
Bronc N Roll
Bronc N Roll
Joe
Newport Arkansas
2023 Bronco
Unfortunately I donā€™t have the up- fitter switches, I appreciate the info, Thanks
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Yes and No.
So there IS a fog light wire on each side, behind your tow hook. But it's not enabled (the circuit is dead in the computer). So you need to
1) Buy the fog switch from Ford and replace your current headlight switch with the combo one
2) You need to program your truck (via FORSCAN) to enable the circuit
We actually make pigtails for all different lights that plug right into this factory circuit.
We also make our own fog kits with Diode Dynamics, Baja Designs or Morimoto lights.
Check out our website for your fog kits and when you decide on which kit to go with, let me know so I can tell you WHICH pigtails to get so you can connect 1 pair of lights to your factory circuit
Everything with the KR Off-Road bracket is on sale now (discounts applied once added to your cart)
https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/fog-lights/
Ford Bronco Modular bumper Question fog light question Diode4
Muddog899
Nm
18 f150
Where are the wires hidden I took off the covers and didn't see anything by the tow hooks
AZ Rider
Larry
Bullhead City AZ
Ford F-350 7.3, F-450 V10 Class C, Jeep Liberty
The fog light wiring is only on the Lux package. Since you donā€™t have the up fitters itā€™s a lot to get the wiring to the light switch and as mentioned there is a new switch and Forscan work. You could run the wires to a switch that comes with some fog light packages. There a whole thread about fog lights. Do a search here.
Ducati1098
High or lux
Any vehicle that has front park aid sensors, also has the fog light wiring.
