- Adam
- Aug 30, 2021
- 456
- 5,281
- 6,529
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
Give that Bronco some much needed lighting with this Triple Fog Light Kit for the 2021+ Ford Bronco. We pair our KR Off-Road Triple Fog Light Brackets with your choice of three pairs of Morimoto 4Banger lights, for the ultimate fog light setup.
The KR Off-Road brackets are made out of 12 gauge stainless steel right here on Long Island (New York). Powder coated black to ensure a durable finish, these heavy-duty brackets feature multiple mounting positions ensuring your brackets not only stay on the truck, but offer you adjust-ability as well. You'll be able to rotate the lights left, right, up & down allowing you to focus the light precisely where you need it. On top of that, the lights sit in a channel which allows you to slide the light left or right.
Included are the following:
https://www.4x4truckleds.com/morimo...t-kit-for-2021-ford-bronco-hd-modular-bumper/
Morimoto 4Banger LED A-Pillar System for 2021+ Ford Bronco
https://www.4x4truckleds.com/morimoto-4banger-led-a-pillar-system-for-2021-ford-bronco/
Bolt on Brighter: The Morimoto 4Banger A-Pillar LED system is the perfect solution for more light, aimed exactly where you want it. From long-range spot-lights for high speed driving to ditch lights to illuminate the side of the road, our A-Pillar kit is all about versatility. Select a set of high performance 4Banger LED pods in your choice of beam pattern and power it properly with our switched wire harness.
Engineered Fitment: Morimoto's A-Pillar kit for the 2021+ Ford Bronco has been through numerous rounds of design, prototyping and testing directly on the truck to ensure perfect compatibility. Everything lines up with pre-existing mounting points to create an installation that is truly modification-free. Guaranteed. Yes, we agree this is a basic requirement, but you wouldn't believe the poor fitment we encountered from other well-known brands during development. It was mind blowing.
All Weather: The white-output version is ideal for all-around visibility. For those who desire optimal output in rain, snow, or fog--the Yellow-output version will slay in shady weather. Morimoto has opted for Phosphor-Converted Yellow LEDs that produce yellow light at the origin, which is the most effective way to penetrate through particles in the air without compromising output (Filtering white light through a yellow lens achieves the look, but no actual performance benefit in poor weather).
- 1 Pair of KR Off-Road Triple Fog Light Brackets
- 3 Pairs of Morimoto 4Banger Lights
- Upfitter Wiring Harness (If you don't have upfitters we recommend an auxiliary switch panel)
- Instructions
- Our Lifetime Guarantee. For as long as you own your Bronco, if you manage to break/bend/destroy the KR Off-Road brackets we'll replace them free of charge (not including return shipping)
