MORRFlate vs Thor’s Lightning 4-tire air hose?
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
I have the Morrflate two tire version (didn’t want to put away four snakes) and a Morrflate portable compressor for 1-2 tires (wanted to use it on my motorcycles as well). Quality stuff.
Agreed, I run different pressure, front and rear of my other vehicles so the 2 tire system works great.
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
No experience with MorrFlate, however I do have the Thor 4 tire system and love the quality of the hoses. They're flexible at all temperatures and have a quality rubbery texture. Only drawback on both systems is the digital gauge. I wish they were analog so I don't have to worry about dead batteries. I may look to replace the gauge at some point.
Cajun Czar
Robert
Louisiana
F-150
I have to admit that is an issue with the MORRFlate. I have to take the batteries out after each trip due to the button sensitivity. Learned that the hard way. So what I do now is keep the batteries in a baggy in the pocket of the case and pull them out when I use the MORRFlate.
Roofus
Roofus
Swamp
M3/Bronco
Good tip 👍
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
I asked the MORRFlate owner why they didn't have an analog option—seems like a no-brainer to me. He gave a rather lengthy and somewhat insightful response if you care to read it.
I do agree with what he said, but I still think analog is the better option, the benefits of having a slightly inaccurate-but-working analog gauge outweigh a digital gauge with a dead battery in my opinion. Got an analog gauge with 1/4" NPT threads sitting next to me right now and will be swapping that in. (Luckily you can buy the MORRFlate kits without the digital gauge to save some cash.)
Jmanly
Joel
Phoenix
2018 Rubicon
I have the Thor's system and mounted the compressor using their Refuge molle mount. The quality is very good.
Jfigueroa
Jared
Kansas City
Ford Bronco
I have the Tozalazz compressor and 4 tire system. Paid 380 total on Amazon and so far it’s worked as advertised. I’ve only used it a few times but no complaints so far.
j_marinelli
Spring Branch, TX.
Followed this DIY video which might be similar
Ford Bronco MORRFlate vs Thor’s Lightning 4-tire air hose? 20220407_064027
I think I spent around 100 bucks on it (I did have a few items already) though that was 18 months ago so not sure what the cost would be.
TheShark
'23 Bronco 4DR Wildtrak,'24 Maverick Lariat Tremor
I just bought the Thor system, with their 25% off Black Friday sale and had a coupon for an additional 10% off it was a great deal. I have a ARB under hood dual compressor, looking forward to be able to do all four tires at the same time.
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White (sold) & '23 Jeep 392
Just as another option, I use EZ Flate Recoil system as it fits nicely in a packout. They also have the standard hose type but I always hated unrolling/rolling them.
Razorback
Bill
Dallas
Lincoln MKX
I have the Thors along with their extension. I imagine it's not much different than any others. Air up both Broncos from 15lbs to 35lbs in a few minutes. Lot of air passing through. I only had one issue with the ARB connection. It got so hot it did blow the hose at the connection. Finished with the spare ARB hose. Contacted Thor and they said they are changing the connection hose going forward (I was an early adopter). They sent a replacement no questions asked. I also like their fast connect chucks ALOT!!!
GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
I have had my Morflate for going on 4 years now. It's great. I probably would have going with Tricky Dicks setup if it was available at the time. It's very similar, cheaper and he's a forum member.
I can air down all 4 tires from 30 to 15. I tend to run the rear just a little lower so I close the valve, take the fronts off and open it again to get to where I want it. Airing up with my ARB twin compressor is fast. My open complaint is putting it away. I may buy a 2 tire kit to keep in my First Edition and just permanently keep the 4 tire one in my 1970 Bronco.
Canyon Coolers
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
I got to meet all the Morrflate guys (Travis and company) at an event about 8 weeks ago, and go wheeling with them. Super nice guys they demo'd everything and they do a ton of free recovery at King of Hammers every year. I want to switch over to their stuff and would not hesitate to do business with them now or in the future. Geat guys that really live what they are selling.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I have the MORRFlate 10.6 with the four tire kit. The pump itself is great, if maybe a little pricy (not on sale). The digital gauge is trash, but apparently they're not the only ones that use it. I've been out with folks who have the Thors Lightning and I'd say they're very comparable right now.
Having said that, MORRFlate has a new version coming out sometime in the next few months that they announced on the Snail Trail podcast. Basically, they say the overheating and lack of depressurization for the compressor should be a thing of the past. So they'll last longer and you won't (presumably) need gloves. They were talking (early November) of a small (?) price increase as well as upgrading current orders for free.
My biggest gripe about these four-hoses-and-a-boat-anchor-compressor setups is that they're so heavy and take up so much (awkward) space. To do over again, I might go single compressor Viair with two hose setup. So much smaller to haul around.
A note on the high capacity air compressors: The 10.6 is fast. I've gone from 15psi to 35psi in 3 minutes. However, the setup and teardown, once I got used to it, still takes like 30m. While the airing up is faster, the overall put up and teardown takes longer than a single our two tire setup, if you're not a NASCAR pit crew. I don't believe you're supposed to use the 10.6 in single or two tire configs for long, due to wear on the compressor.
