Motorcycle vs Bronco modding
ilbastarge
Northeast
New here and curious:
My m/c mod thought process figured "Marine grade stuff would work well on bikes due to the water resistancy". Anyone have that same internal policy about modifying their new 4wd?
Advertisement
ZackDanger
Zack
Massachusetts
2014 Wrangler JKU
I’m having trouble understanding what you’re saying. I think you may have accidentally your post.
ilbastarge
ilbastarge
Northeast
Sorry about that. It might be lasting concussion issues.
I meant to say: Since m/c are out in the rain that marine grade stuff is what I used for any mods (electrical etc). Because the Bronco can have the top removed would that same theory apply?
Hope that made more sense.
ZackDanger
Zack
Massachusetts
2014 Wrangler JKU
Ah I see!
It sounded like you were asking if we were planning on using marine grade vinyl (MGV) on our Broncos because it works so well on bikes... and we were confused because some Broncos already come with MGV.
We know the hero switches and steering wheel controls are encapsulated and water resistant.
Come from the Jeep side of the house I’ve never felt the need to use marine connectors or anything for items inside my vehicle because I’m not running into scenarios where things are getting that wet. Compared to my motorcycles things never got as wet in the Jeep as they did on a bike.
Even then, imagine the space immediately behind your windscreen on the bike and how relatively dry that stays. Inside of the Bronco will be the same except for when you’re parked... and that’s just for the stuff that’s actually exposed. Most connectors will be tucked away behind trim and dash.
Of course if you’re going to be running with tops off a lot, and figure you will inevitably get caught in the rain, it would be of benefit to consider what materials you are going to use for your mods. Sounds like you’ve got a good sense of that already.
My experience is that basically everything dries out eventually and the stuff that doesn’t, like electronics, aren’t being left out in a vehicle with it’s top off... or are marketed for this type of vehicle and are already water resistant.
YMMV.
ilbastarge
ilbastarge
Northeast
Ah I see!
If you’re going to be running with tops off a lot, and figure you will inevitably get caught in the rain, it would be of benefit to consider what materials you are going to use for your mods.
YMMV.
Well, Southern Maine to Western MA is my intended AOO. I'm old so not doing any Minuteman 1000/Saddlesore 1000/Bun Burner 1500s anymore. Not in the Bronco either. :D
EDIT: Looks like you do/did track days (at least) on your bike. Still active?
ZackDanger
Zack
Massachusetts
2014 Wrangler JKU
I’m in Western MA and race vintage classes in the USCRA at Loudon NHMS and Canaan NH.
My MM1000 days are long past, and I’m not even that old. Still go camping on the motorcycle though... but I realized a while ago I didn’t have anything I actually needed to prove. ;)
ilbastarge
ilbastarge
Northeast
I just do things to "prove myself to myself". Maybe that should be a concern.
OT - Is there going to be a general "Troubleshooting" section here? I see the specific system areas (suspension, electrical, and the like). Figured there might be a "General" one to give an idea where to start the research... 🤷‍♂️
DeltaBravo
Delta
MIKES MOM
flip a coin
DeltaBravo
Delta
MIKES MOM
Fair enough. Just trying to learn the place and people. Thank you. I appreciate the guidance.
You are very welcome. Expect the same level of guidance in your personal life decisions from strangers on the internet any time!
Advertisement
Wide Open Roads Banner 1
Advertisement
