Zip ties under the column. Easy and you can access in seconds. Only drawback is you can't adjust the wheel all the way down but IMO any lower than max it is way too low anyways.
M2M makes a great dash setup but fair warning getting the wiring down is a super PIA.
I’ll be moving mine there for sure. It’s above the glovebox today screwed to a piece of pine that’s mounted to the same place the M2M bracket uses. I want to move it then move the yaesu radio up there and out of the way. I just have t figured out how I’ll get to the micro SD slot when I need to
I just used sticky velcro. I like that it offers a small amount of vibration damping to the amp and is easy to access or remove if necessary. Anyone else have minor clearance issues with HVAC ducting under there?
