Mounting 5 pound propane tank on a rotopax ez tire mount?
98infinity
Alberta
16 F150, 20 Road King, 22 Bronco
emulous74
Seth
Austin, TX (Pflugerville)
'19 ZR2 Bison D , '23 Bronco 2DR, MT
You are going to have trouble mounting it directly to that, I can't see a safe way to mount it unless you are able to mount something like Expedition Essentials Propane Quick Bottle Mount. I've tried a large Quick Fist, but it doesn't fit well around a 5lb propane bottle.
https://expeditionessentials.com/co...products/propane-quick-bottle-mount-pre-order
Ford Bronco Mounting 5 pound propane tank on a rotopax ez tire mount? 766973BC-DAC0-48BD-B8D7-45D1C106D1E7_1_201_a_2000x
I've been wondering if it's possible to mount that to RSE's or Overland Kitted's tire mounts.
98infinity
98infinity
Alberta
I would imagine it would work with the Overland kitted tire mount. Very cool
98infinity
98infinity
Alberta
can see a 5 pound mounted here on Barry Bonds Raptor on a rock slide engineering ez tire rack looks like it might move around a bit just from him closing the door
emulous74
tdiddy
Tommy
Illinois
2010 Ford F150, 2012 Ford Focus
This is a 10lb tank mounted to a PowerTank mount.
Ford Bronco Mounting 5 pound propane tank on a rotopax ez tire mount? 20230106_154400
98infinity
98infinity
Alberta
tdiddy
Tommy
Illinois
Is that the gobi rack? How do you like it?
Yes, it's the Gobi. I like it a lot! I bought it a year ago and received it in Nov22. I have a roof top tent, 270 degree awning, and a waterport that I will install on it for trips. Only downside is that I have to keep my Coilovers set low or I can't fit in my 7' garage door.
IwannaGOfast
Jon
Brea, CA
1991 Ranger Long Travel, 2014 Cruze Commuter
nwGTS
Nate
Chicago, IL
Porsche 911 GTS, BMW M3, VW Golf
@98infinity
I messaged @nwGTS the other day to ask him about his propane mount. He is using the rockslide spare strap with the following mount:
https://www.etsy.com/listing/1231367353/propane-tank-mount
He said it's very well made/designed. It's also cheaper than the powertank mounts I have seen.
I didn’t think once about my tank going up and down Engineer’s pass and all over Moab which is the point I suppose.
It’s a terrific mount.
Note: I’m forgetting if it came with the strap but it was clearly designed to have a strap run through the mount and around the tank to further secure it. It also locks.
It’s perfect.
Ford Bronco Mounting 5 pound propane tank on a rotopax ez tire mount? IMG_7911
Ford Bronco Mounting 5 pound propane tank on a rotopax ez tire mount? IMG_7669
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
BroncoA512021
Long Island, NY
www.facebook.com
Durangatan
Marty
Durango, CO
Bronco, A6 Avant, TTRS, SQ5
How many weeks do you get out of a 5 gallon tank?
