MT vs AT tires for daily driving?
BadSquatch
Wilmington, DE
72 Bronco
Badlands, 2Dr.
How will the MT tires be for daily driving? I don't know how much I'd need the MTs (if ever). But, get them, just in case?
Also, going through the builder on Ford's website, if you toggle back and forth between the MTs and the ATs, the MTs look bigger/better (try it). They have the same dimensions, so they should look the same, right? Maybe it's just the builder?
Every time I build out my Badlands, it 'looks' better with the MTs.
Thanks!
GoldenKnight
IL
Malibu
I think B&P shows the Sasquatch sized version of the tires on the smaller wheels when you select them. If you zoom in you can clearly see the pictures background through the area between the wheels and tires.
elnorte
Seth
Dakota
Badlands, 2Dr.
Thanks!
The B&P puts a really odd gap in the 33" MTs. So odd you can see the back drop landscape. I need to see it IRL to decide.
Chuck_Ruck
Chuck
Arizona/Nomadic
F150, Wrangler, Eldorado, Harley, Triumph
MT have a more aggressive tread pattern. They look bigger in every case because the tread depth is much more noticable. They will wear faster too. After about ¼ of their life they will begin to hum at speed. More on road use, stick with the ATs. Buying tires gets expensive after a while.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
It’s been mentioned several times in different threads here, but Ford interchanges the Mud Terrain name with the Good Year Terrain tires, that are “max traction “ on the SQ package. They are an aggressive all terrain tire, but definitely not mud terrains. I believe the only Mud Terrain tire is the 33” option on the Badlands. That may be what you considering, but otherwise the Good Year Terrins should be pretty versatile from the reviews and descriptions available so far.
Adumb
Adam
St. Louis
'21 Area 51 4dr
Can we really call these Territory tires MTs though? If you'll give them "max traction" over "mud terrain" would it still be safe to assume the similar difference in driving experience, maybe just to a smaller degree?
2Jeeps&PatriotX1
Denver, CO
I daily drive 2 vehicles (f150 & wrangler) with 35” true MT tires (54 miles roundtrip to/from work) average speeds of 70-75mph. I drive 20k+miles a year on my truck. Wife’s grand cherokee has AT tires as well. I rotate and balance all tires every 3k miles. Driven 60k miles on MT tires between the truck & jeep and wife has 40k miles on her AT tires. All vehicles see heavy offroad as well.
Jackattack
Jarmon
LA
Bullsh
For daily driver. Go AT's. Better gas mileage, longer life, better traction on the road, less noise, more control, ever so slightly better handling. If your not going off road at least once a month or more then MT's arent a sound economic decision. If you like the bigger look, buy bigger ones when those wear down. Thats my plan and reasoning at least!
HoosierDaddy
__ Eric
Indiana
AT over a true MT (Mud Terrain) for daily driving....every time. The MT's will eventually get loud and will not do as well in inclimate weather while ON ROAD than the AT's.
The tread of the new GY Terrains looks very promising , there's a decent amount of siping, which will help for icy/snowy conditions. I'd run them and see how they did that first winter.
attworth
Tony
2000 Land Rover D2
BFG KO2’s are a great tire. Unless you have a real need for something more aggressive, I don’t think you’ll be disappointed in its performance.
PartyMarty
Marty
2016 Jeep Wrangler Black Bear, 2009 VW Rabbit
I'm getting the 35" sasquatch MT tires when the vehicle is delivered. Apparently these are technically "maximum traction" tires and not mud-terrain tires. Either way, I'll live with it for the first 40k miles or so till they wear out and replace them with BFG KO2 all-terrain tires.
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
Actually, the Badlands optional 33" is the same Goodyear Territory (Max Traction) tire as Sasquatch 35", just a smaller size. It has been designed specifically for this vehicle and should have better on road manners than a mud terrain.
I'm getting a non-Squatch Badlands with optional rims, but can't decide which 33" tire. I like the Territory, but sticking with the excellent K02 saves $695.
Frank N
Frank
NJ and Outerbanks
2018 Ford Raptor
Look at it this way....
Risk 695 and not sure if you will be happy or save 695 and get a no doubt proven tire...
