My base 4door will be built in Oct. how much for 5” lift and 37s?
Mnext02
Hellcat
Teke
Colin
Indiana
01 Mustang Cobra
Please do a proper lift. That massive spacer lift is going to cause issues.
doyouglas
Douglas
Southern California
Toyota Highlander
Are you going to do a spare tire delete? If not, I'd invest in in 5 wheels and tires not 4. That would like weird if you kept the stock.
Also +1 above. Do a proper coil lift. For an additional 500, I have the Eibach coil lift that can do 4" lift.
Spend the extra money and do it right the first time... that way you don't have to spend more money fixing your issues. Another thing you may want to consider... running 37s with 5 inch lift will ride very rough at high speed. Your steering wheel will shake at high speed if not done properly.
Also assuming you have the non squatch base model, you will have some weak gearing to run 37" tires. You'll need to regear to maximize driving efficiency with 37. A lot to think about. Good luck.
Mnext02
Mnext02
Hellcat
What shop in SoCal do you recommend? Im in Ventura county
