I'm under the understanding Badlands has Baja and the only difference is sport-2H while baja-4H...but you can switch back to 2H once in baja. Baja holds RMPs longer than sport as well...You don't have sport or baja mode on Badlands.
What does baja mode do? Add guacamole?
Yes, you do get Baja, not Sport... No Rock Crawl on Wildtrak. Fair exchange for intended use.You don't have sport or baja mode on Badlands.
I swear the specs on ford website showed wildtrak having AUX switches.If you want to add power accessories down the line, don't forget that the WT does not come with the aux. overhead switches (nor is it listed in options). That may be worth something to you as it would cost you to replicate them
edit; spelling
Yes if the Wildtrak does not have AUX switches thats big. I would like to add lights for desert running.I swear the specs on ford website showed wildtrak having AUX switches.
If you read on Wildtrak if says right on it, comes with Badlands standard equipment. That includes the over head switchsI swear the specs on ford website showed wildtrak having AUX switches.
The Wildtrak has the auxiliary switches listed as standard equipmentIf you want to add power accessories down the line, don't forget that the WT does not come with the aux. overhead switches (nor is it listed in options). That may be worth something to you as it would cost you to replicate them
edit; spelling
I wish you could add the steel rear bumper like the badlands.
Yes this is the badlands Not the Wildtrak.Your wish has been granted. That was your only available wish. Good luck.....
No, did you not read? This Package is available for all trims except the two that already have it.Yes this is the badlands Not the Wildtrak.
Wildtrak comes with plastic covered bumpers
