My dealer called - dropped tow package
G8Rengineer
Port Orange, fl
1992 Jeep XJ (original owner), 2012 Ford Expeditio
I have a July 18 reservation and a Feb 25 (PC 19) conversion for a 2 door Badlands, 2.3 Manual Transmission, Area 51, with tow package.
Yesterday I had an email from my dealer (Mullinax Ford in New Smyrna Beach, Florida) to "call about your Bronco Order". I generally feel I know more than the dealership. Today was different -- his comment - drop the tow package and I should be able to get in line.
I wanted everything to be turnkey and stock from the factory but I went ahead and dropped the two package, if I had to give up anything that seemed like an easy choice.
Wanted to post here so if I get an email with a VIN it is documented.
JOHN
Advertisement
Rollerstud98
Christian
Airdrie
2015 Nissan Titan
Mid, high or lux? I have same build with lux, kept the tow and received my vin already with pushed back to July 19 build. If you really want tow package I wouldn’t sacrifice it just to receive the Bronco a couple months earlier.
Rubisquatch
Pittsburgh, PA
13 10A Rubi, 14 HR Rubi, WRX, 19 Edge
Canada ordering / VIN selection doesn’t apply here. I guarantee you the scheduling rules are different. Please don’t take this the wrong way cause I love Canada, I’m just stating this based on observations form reading thousands of posts here and seeing who got what from where. It seems like many Canadians got their VINs early while here in US you need priority from the dealer, have an early FE or super early res with low commodities (like removing tow) to get scheduled. Pretty sure the first few VINs on this site we’re from Canada and that’s really odd when Canada is probably 1% of all orders.
OP, youre chances are way higher to get scheduled removing the tow.
G8Rengineer
Port Orange, fl
Mid package.
Tow package - my understanding is it is nothing more than the hitch and wiring harness, easy enough to pick up in the aftermarket. I was not considering giving up anything but if this gets me in the queue I can sacrifice it for now. My concern was being a PC 19 and getting pushed to 2022 (assuming the 19 means I am at the back of the line at my dealer).
On a side note -- I did sign up for Austin this past week and am going to Roadeo Aug 6. can't wait to actually drive a Bronco!
Creepystalker
Kc
Los angeles
2014 Silverado
I am in a similar situation. I understand the tow package is low commodity but the hard top is much more effected. I decided to keep my build as is. If I keep it long term is will be a low volume option list.
Funkdoobiest
Buffalo
Ford Bronco Basesquanch First Edition
JOHN
I have orders for a base and a FE, neither has the option of getting the tow package. From what I have been gathering there is more to the tow package than just the receiver and harness. The factory accessory harness appears to only be a 4 wire hookup. No one seems to know for sure what the Bronco will come with from the factory when no tow package is ordered. I wish I could get the factory installed tow package and if I could I would wait for it.
G8Rengineer
Port Orange, fl
It was a tough call. I have an expedition with factory tow.
But, in the end row for me is for a bike rack or extended cargo rack to throw a cooler and gear on. At 3500 lbs on a small wheel base it will be used for jet skis or a uhaul, something light.
I still feel it will be several more weeks before a VIN and I’m betting October for delivery. We will see as there seems to be no logic to the process.
Desert_6G
Phoenix, AZ
Ranger
Keep the tow. You should be in good shape. But if you had the LUX or SAS then those will likely delay it. But not so much the tow.
UtahBrandon
Brandon
a number of classics and daily drivers
On Friday May 21 I called to drop the tow package on my 4dr 2.3/auto Badlands with MIC top and Lux package, and the following Thursday the 27th I got my VIN. 7/13 reservation.
Could’ve been coincidence but I only intend to use the hitch for a bike rack anyway so I’ll just add it when I get the vehicle with a July 19 build week.
I think the moral to the story is that everyone is full of misinformed, bad advice so stick with what you can live with and don’t sacrifice too much based on all of this speculation.
Bulletbill
FL
Honda
Honestly, I wish Ford would send an email letting you know what the constraints were holding up your particular build so you could decide to keep them and wait, or drop them in lieu if getting your vehicle faster.
I imagine vague emails and rumors are causing most of the frustration felt by their customers at the moment.
ZackDanger
Zack
Massachusetts
2014 Wrangler JKU
Mid package.
Priority codes don’t work that way with the Bronco. Anything 10-19 are the same priority, instead Ford is using timestamp for ranking.
Brongo
Northeast
Jeeps
I feel the same way and I ordered the same as you in a two door. Did you get a two door? Or four door with soft top?
Brongo
Northeast
Jeeps
EXACTLY. The vague mass emails give us no guidance whatsoever. When I told my dealer I would drop tow to get a build date he laughed. But then again they’ve been useless.
Advertisement
BuiltRight
Advertisement
