- Thread starter
- #1
We have a 2 door Black Diamond on order. My Dog needs a inside measurement for his crate. ANYONE with access to a 2 door, can you help him? The crate is steel, 22 1/2" wide.....it is the width he is concerned about (not concerned with length or height). His plan is to remove one rear seat and then the crate will go in it's place; behind the front passenger seat, facing to the rear. His concern; will it fit? He needs the dimension between the rear seat that is still up/in place (the rear seat behind the driver) from the edge of that seat over towards the right inside wall of the Bronco....as his crate will be up against the rear seat edge (the seat remaining). The diagram below shows an overall inside width of 43", divided by half it won't....but, there is space between the seats and it all depends on other factors than just looking at this drawing. He realizes he will need to do something at the floor to make a level surface for his crate to sit on.
Can anyone help with a in-p
erson live measurement? Axzel thanks you!
