My FE gets 33+ mpg hwy
Packman
Honolulu
2011 Ford Mustang Pace Car
Ford Bronco My FE gets 33+ mpg hwy 3F6B8CB4-542C-4616-B32C-A2824144A3D4
…at least for about 10 minutes driving downhill. But still, she is capable of better than advertised hwy miles if you start the trip meter once you are actually on the hwy. My city stop & start driving is about 16.8 to 17 mpg the last almost 1K miles.
HotdogThud
mk6 gti, '21 MoarDoor
I've gotten pretty good mileage on mine when in stop and go traffic that's puttering along at 45 or so. it's the mad aerodynamics on the bronco that's killing the mileage above 60-65. the dropoff is almost comical.
khudgi
Kurt
Tecumseh Michigan
2018 F150 XLT 4x4 CC / 2023 F350 CC LAR 4x4 PS 6.7
Yup 14.5 to 15.2 on mine.
NotApplicable
BEVs
My FE is at 18.7 mi lifetime avg over 5100 miles
clarkT
PA & KY
2001 Mustang Bullitt
Legit doing upper 20s with big mix of city and highway over a couple hours today. Using ECO and taking a long view of the road for slow acceleration and deceleration. And using the auto stop which really helps Mpg in city. I disabled it till my experiment today and I will now be learning to deal with it. It’s not bad if you can let go of the brake right before the light turns green. Then no lag. And a gentle takeoff (max 2000 rpm goal) and you’ll be upper 20s in any model that has 3.73 (base OBX). It does nose dive mpg at 75+ so interstate cruising at 65-70 seems ideal.
69BroncoX302
1969 U15, 2021 First Edition
Yeah, the FE mpg is 17 hwy and 17 city. Still scratching my head how that works. But cheers to the gent that is getting 18+.
Stampede.Offroad
SD
junk
Overcoming terminal velocity is energetically expensive.
Ain't gonna be no Bronco shaped airplanes.
Deleted member 9490
Guest
We must have trash gas in Utah because even on 91 I am barely getting 16.0 after the first 1k miles.
indio22
Chicagoland, USA
Cruising down I70 from the mountains towards Denver, I would sometimes put my CJ-5 in nuetral and turn the engine off. :)
lakesinai
Charleston SC
Would you make a fuller, complete report? See the one I just posted!
malt_liqueur
Portland
Tacoma
mad aerodynamics indeed!
